Aluminium window frame bubbles
Hello
A few days ago I was asked to wrap a powder coated window frame, which is part of a display for an exhibition.
The profile was as shown in my picture…
I primed the inside corners. I used Avery Supreme white using a single piece
I began by tacking the vinyl to the outer frame, which was flat, all the way round, and squeegeeing that down.
Then, heating mostly in the centre, I pushed the vinyl down into the inner frame, cut round the edges and folded down into the inside lip, and trimmed above the rubber. I post heated the hell out of it when it was finished, and left a perfect job – so I thought.
Customer calls the next day.
It’s started to bubble.
So I went back, and sure enough, there was vinyl pulling away from the inner corners.
I did my best to push the vinyl back, but it is a losing proposition, and I will have to do it again.What did I do wrong?
it wasnt a very big drop, so the stretch couldnt have been more than a few percent in the corners, and I took most of that from the middle, which was cut out.
