Home Forums Sign Making Discussions General Sign Topics Aluminium Trim Profiles similar to Eurotrim
  • Aluminium Trim Profiles similar to Eurotrim
    Posted by Glenn Sharp on 21 August 2019 at 08:52
    Hi all
    Its a while since we made a sign using aluminium trim and hanging panels but we have a job to do using this method
    Back in the day we used to use Eurotrim with perspex panels on hanging strips and when it was necessary to load from the front we would put springs in the two side pieces to force the panels together
    The sign we are doing now is 9m long x 900mm high and will need to be 3 panels, loaded from the front but in aluminium composite – our supplier stocks Nova Trim but I’m drawing a bit of a blank as to whether the springs are necessary or even exist for their 204 Composite profile
    Can anyone shed any light on that for me or point me in the direction of other profiles that will take a composite panel?
    Alex Crosbie replied 6 years, 4 months ago 3 Members · 6 Replies
  • Fred McLean
    21 August 2019 at 09:05
    Composite panels will fairly rattle about in the trim will they not Glenn? Without packing them out with somethimg!
    Are those trims not designed for 5 mm thick sheet?
    Folded box not an option?
    Fred
  • Glenn Sharp
    21 August 2019 at 09:27
    Hi Fred,
    The NovaTrim Composite 204 is specifically for a 3mm panel so I’m hoping its up to the job
    The customer was offered the folded box option (which was slightly more expensive) but favoured the trim
  • Alex Crosbie
    21 August 2019 at 10:49
    Very interested to see how the front loading works with springs holding them in! It’s an issue I’ve come across a few times so curious to see how it works
    If you could post photos that would be great
    Alex
  • Fred McLean
    22 August 2019 at 07:29
    Didn’t realise there was a specific 3mm trim on the go.!!!!!
    F
  • Glenn Sharp
    22 August 2019 at 14:11
    Sorry Alex – I’ve managed to convince the customer to go with a tray on this occasion as I started to have real doubts that the trim without springs was the correct way to go
  • Alex Crosbie
    23 August 2019 at 06:31
    No worries! I think I’d have done the same
