Home Forums Software Discussions Flexi Sign Software .ai / .eps file conversion advice please?
  • .ai / .eps file conversion advice please?
    Posted by Brian Little on 24 March 2011 at 09:18
    hi folks having a bit of a problem today .Ive asked the "grafic designer "of one of my customers to send me the design in illastrator or eps so i can manipulate it .He said hes doing them in cs5….but to me its still a pdf wheither he thinks its an illastrator or not when i put it in or try to put it to flexi it comes up corrupted pdf file anyhelp appreciated
    :police: Mod-Edit
    * Please use "Descriptive Topic Titles" when posting.
    * This posts Title has now been edited.
    Please take a moment to look over our Board Rules.
    Brian Little replied 14 years, 6 months ago 9 Members · 10 Replies
  • 10 Replies
  • Stuart Miller
    24 March 2011 at 09:43
    Does Illustrator open it?
    Then you should be able to save as an eps. which Flexi should read.
  • Neil Davey
    24 March 2011 at 10:06
    What version of Flexi are you using Brian.
    8.5 opens PDF’s ok.
  • Tim Painter
    24 March 2011 at 10:23
    Sound like the same problem you get with Corel 12 and CS5 ai / eps files.
    They don’t import and show as corrupt.
    Get him to save as an earlier version ai file.
  • Zahid Jahangir
    24 March 2011 at 10:49
    i heavily use illustrator cs4, you have to find out what version flexi you have and, which version of the illustrator raw file it take (.ai).
    If you ask your designer to export the illustrator file as an .eps, rather than save as which only gives you saving option as .ai or .pdf.
    Can you try to open the .eps file into photoshop, it normally works. I think you can resave in photoshop as an .eps and try to open it back into flexi or illustrator.
    please update us,
    regards,
    zahid
  • Tobias Redig
    24 March 2011 at 11:49
    Try using the "Place" command to place the EPS inside a Illustrator document. Remember to embed the file and not just link it.
  • Brian Little
    24 March 2011 at 23:22
    quote Stuart Miller:
    tried that stuart no joy
  • Catalin Dretcanu
    12 May 2011 at 14:32
    another great graphic designer who have no clue about different versions of .eps or .ai or .pdf files. what you need to do is to have a file about how you want to have your files to be done by outside graphic designers. tell him to save the the file as a .pdf file but an early version which can be open with flexi. you can see that in flexi help about supported files to import.
  • Robert Walker
    12 May 2011 at 19:06
    try
    http://www.filespazz.com/
    its a free file converter just upload your pdf and select the file type
    you want it converting to and they email it you within 5 min
    i use it all the time when people sent me coreldraw files as i use
    illustrator and it works every time
  • NeilFox
    13 May 2011 at 20:41
    I use Illustrator. Instead of saving as an eps or ai CS5, get the designer to save as Illustrator 8. Every version of Flexi from 7, 8 & 10 should open / import that version of Illustrator file fine.
    The file size will be large, but most designers / agencies use Rapidshare or U Send It, so you can pick it up via a file sharing site.
    Neil
  • Brian Little
    16 May 2011 at 06:07
    Jobs long done my friends but thanks use your imfo ill use for future reference
