Home Forums Sign Making Discussions General Sign Topics Advise on how to fix to this beam
  • Advise on how to fix to this beam
    Posted by Warren Beard on 16 September 2010 at 16:22
    I have to fix a flat sign panel to this beam, it’s high up out of reach but there is only the single 60mm beam to fix it to.
    What do you suggest is the best way to fix the panel to it securely.
    panel size is 2000mm x 500mm
    Warren
    Warren Beard replied 15 years, 3 months ago 5 Members · 5 Replies
  • Gary Birch
    16 September 2010 at 16:25
    If its hollow can you not just use pop rivets??
    Gary
  • Richard Urquhart
    16 September 2010 at 16:42
    Pop rivet 3 vertical supports in aluminium along the width of the sign and fix using the beam and the vertical supports that you put in before the sign.
  • Bob Clarkson
    16 September 2010 at 21:08
    I can’t post a pic to describe, shame as it’ll be a lot easier. Get some suitable self made brackets, something a 600mm strips of metal about 25mm wide bend them in half round a piece of wood or metal the same depth as the beam your fitting to. Fix half of each bracket to your board, then just slot them down the back of the beam where the corrugations are. This will make it easy to remove as and when necessary, and also guarantee you can get it level in all angles as it won’t be trying to twist the beam under it’s weight. Done a load of this in a metal Barn at a farmers market once.
    16 September 2010 at 21:13
    two pop rivets, one at each end, or two self drilling tapping screws,
    job done, its indoors so only the weight of the sign need s to be considered, no wind
    6mm rivets would be the smallest I would use
    edit to add info
  • Warren Beard
    16 September 2010 at 21:27
    Thanks guys, just wanted confirmation to make me sleep easy 😉
    warren
