Home Forums Sign Making Discussions General Sign Topics Advice, views on Cleaning Fluids please?
    22 April 2010 at 11:08
    The higher % the better. The diluted stuff usually dries slower though, which gives you time to polish it off. Probably will not make a huge different in cleaning, but the higher the dilution, the more probability that it will leave contaminates on the surface.
  • John Childs
    22 April 2010 at 11:30
    Wot the man said above. 😀
    We use 99%.
    22 April 2010 at 11:34
    Same as them 😀
    Print one do 99% at a reasonable price, in 1 and 5 litres if you dont use vast quantities.
  • Gavin Fawcett
    24 April 2010 at 07:53
    Thanks all for the quick replies, 😀
  • John Childs
    25 April 2010 at 06:08
    Oh yes, and the 70 % will give you a hangover. 😀
  • Kevin Parr
    25 April 2010 at 10:32
    what kind of cloth would you use to put this on if you where cleaning off a car for example with white paper or a cloth
  • Richard Urquhart
    25 April 2010 at 10:54
    Kevin I aways use micro fiber cloths, great and lint free, use for a vehicle and throw in the washing machine.
    25 April 2010 at 11:17
    i use isoprop in 25ltr drums, comes with a pump valve so we just fill smaller bottles as and when needed.
    i use white paper towel on a roll. lint free clothes are recommended.
    don’t use coloured cloth or paper towel as sometimes the cleaning fluid activates the colour dye and can stain a white vehicle body. especially if its a respray.
  • Ruairi O'Boyle
    25 April 2010 at 12:01
    Do you guys use this for cleaning all products before applying vinyl?
    Apart form what Rob mentioned above is there any other potential problems with Iso-prop?
  • Richard Urquhart
    25 April 2010 at 15:59
    I dont use IPA as we have been talking about. I use Avery surface cleaner for all my cleaning, after using many products I find this is the best and removes all traces of dirt and wax, IPA on its own I think does not remove things like tree sap and I fit away for where the vehicle sign can be washed first making Avery surface cleaner the one for me.
    25 April 2010 at 17:57
    with Rich on the avery cleaner not cheap but like the smell
  • Gavin Fawcett
    25 April 2010 at 18:49
    We have been using some white paper towels on the boarding etc and manmade fibre cloths on vehicle panels and glass.
    25 April 2010 at 23:12
    quote Richard Urquhart:
    I’ve moved over to the Avery Cleaner too. Excellent cleaner, Less of a workplace issue when working on site too.
  • Simon Polakof
    26 April 2010 at 18:51
    Has anyone out there used white vinegar?
    It is said to work very good for dissolving lots of different filth.
    I haven’t tried it yet though.
    I’ll give it a try and let you all know.
  • Phil Craddock
    27 April 2010 at 08:52
    WD40 great for removing tar stains.
    then I wash with warm water and use Avery Surface cleaner to prep paintwork and clean off any WD40 residue
    27 April 2010 at 09:20
    quote Phil Craddock:
    Phil, Avery Surface cleaner removes tar anyway doesn’t it?… mine does anyway…
  • Phil Craddock
    27 April 2010 at 09:28
    it does but sometimes like this week I had a MINI here with 8 year old stripes that when the old vinyl was taken off it left all the adhesive – so washed the bonnet in WD40 for 20 mins then cleaned off with Surface cleaner and viola almost like new 😀
    27 April 2010 at 09:46
    "tar and glue remover" can be bought in lots of places, particularly auto valet supply companies and is inexpensive. it will eat into and remove even the heaviest of adhesive in minutes. once clean, just wipe down with Isoprop and Bobs your aunties uncle! 😉
    i haven’t tried the Avery cleaner, sounds pretty good. but been using the same chemicals for years and never had any problem’s, so never had a need to venture onto something new. ill ask for prices and compare… 😀
  • Phil Craddock
    27 April 2010 at 09:54
    I agree Rob, when you find something you are comfortable using there is no need to change 😉
