Home › Forums › Software Discussions › General Software Topics › Advice needed reinstalling Windows XP ?
Posted by Cheryl Smith on 26 October 2012 at 15:18I am having no end of problems on the laptop I use for running versa works, cutters etc etc…jobs printing half way and then the comp black screening…corel seizing and generally feeling Im wasing my life away….everything is seizing now…
ive tried defray…
Is it best to totally wipe the comp and start again?…how much effort does that take and how long?…any advice greatfully received…Ive got a que of work to get through!!Stephen Morriss replied 13 years, 1 month ago 9 Members · 44 Replies -
For some stupid reason it doesnt have a system restore point either..
know how to do it now…..grief these things can be…! on a Friday night too…
I feel your pain Cheryl! Have just come through some issues here too.
You will need to re-install all programmes if you go for a wipe, and save all files.
If you have the XP disc a ‘repair’ option might work and is worth a try at least. Google ‘doing a repair in XP’ and you will find many good tutorials on doing it. Same for doing a full wipe and re-install. Best of luck and have plenty of wine on standby! -
quote Harry Cleary:I feel your pain Cheryl! Have just come through some issues here too.
If you have the XP disc a ‘repair’ option might work and is worth a try at least. Google ‘doing a repair in XP’ and you will find many good tutorials on doing it. Same for doing a full wipe and re-install. Best of luck and have plenty of wine on standby!Thanks Harry…a burden shared is a burden halved…
I currently have vista on the laptop and hate it…(I dont use it much…my lad does)
but wondered about a full wipe and install xp which I have a copy of…should be straight forward???????
I have a couple of nice wines…er red or white…choices choices… -
Vista has always been a pig! But it may be that there is something starting up at start time that is conflicting and causing the problems. If as you say your lad is using it possibly some gaming stuff? – can be hard on video etc. Might be worth checking what is starting up at start time. If you haven’t already done so, remember to have all your data files (customer designes etc) backed up before you do anything. Then as Harry says, I’d try a repair from the vista CD first.
quote NeilRoss:Vista has always been a pig! But it may be that there is something starting up at start time that is conflicting and causing the problems. If as you say your lad is using it possibly some gaming stuff? – can be hard on video etc. Might be worth checking what is starting up at start time. If you haven’t already done so, remember to have all your data files (customer designes etc) backed up before you do anything. Then as Harry says, I’d try a repair from the vista CD first.
He only uses it for work stuff…no gaming..
no vista disc either…
how do you find out what runs on startup?ill google that…
quote Dave Rowland:how hot is it getting?
ooh Matron! 😮
ooo, the machine..not thought of that…as hot as any other maybe? it is quite old now…should I stick a hoover in its gaps or something?
Ive been backing up files all night (while I had a bottle of wine and went to bed)…so going to have a go at it this morning…
Thought I might have solved it with sorting out all the start ups… Gone to print in versa…started… Went to export file from Corel..everything seized…CNt alt delete wont even come up… Another print knackered….now it’s just gone back to black screen.
Started printing again out the blue with this error message…failure..security options. Error box title…log on process has failed to create the secutity options dialog….stopped printing again …
Gunna try the product recovery disc now….fingers crossed
try using it with a book under it away from any fan inlet
Thanks John
quote Dave Rowland:try using it with a book under it away from any fan inletDone…. :thumbsup:
You can also buy a plinth with a fan in it which will cool the laptop down, I think it plugs into the USB for power. PC world sell them about £20 I think??
Jason.
I’m pretty sure it’s not overheating…..but I’ll guess I’ll find out for sure. After install….
if Ctrl Alt Del doesn’t come up then something is up… heating is normally the main problem but you say no. Mine cooks at 80deg sometimes, it is getting knackered.
Do you get Blue screen’s of death? White text on blue background and reboots
Sound’s like hardware problem, sometimes the laptop screen connector can be loose, but showing u how to take that apart is sometimes best left to an engineer. The clue is black screen but Ctrl Alt Del *SHOULD* could up regardless of anything, it has top priority!
p.s. running versa or any RIP is never advisable on laptop, due to the "power saving" / sleeping design of most laptops
Looks like it it’s hardware…. I have used this hi spec toshiba for years for cutting…no problems .
had blue screen but nothing like as much as black screen…. May need new comp…recommend any off the shelf for running versa am and the usual softwares? -
One last try at reinstall then off to PC world if no joy….
I don’t know for sure …but Italy looking good on the reinstall so far….I shut it down before it finished last time as the screen went blank….
Is it 1-0 England vs Italy?
How much of your kit is USB? or Serial?
Watch out for Win8, this is the new operating system released yesterday, its bag of bolt so try before you spend.
My fav laptop is the new 13" imac with retina display for £1,449.00 incl. VAT
http://www.apple.com/uk/macbook-pro/I know ur a mac girl but they make great Bootcamp PCs
What do you mean by boot camp my dear?… Please educate? I wouldn’t like to buy another PC… But doesn’t versacam need PCto run…or can I parallels mac and cutter/printer etc run from that?
well im surprised you not installed bootcamp on your mac… parallels allows u to do the same but allows it to work within the mac.
Bootcamp is windows for real using mac hardware.. it turns it into a real PC
this is XP, but all Windows CD’s are fine
$this->auto_embed_video(‘http://www.youtube.com/v/P2dQFHWX3HQ?version=3&hl=en_US’, ‘560’, ‘340’)
Ooooyeah nooooo..nice to have windows as something separate on the mac that you only turn on for cornel draw or something…I would hate to turn on mac and find windows there…wrong! …I’ve really fallen for mac…
I’ll have a look at the link when I’m off the iPad. Windows updates for 6 years taking an age to load…. -
aw I get it…good link by the way…easy to understand… I like to able to switch between mac and windows without reboot…on my main iMac,
but should I need another comp for the printer…I can see where it would come in very handy!
wondered what bootcamp was..ive seen it on the mac somewhere… -
well I have the same mac in front of me at work.. i did have parallels working but it needs an upgrade to work with mountain lion but it is slower.
Bootcamp allows u to boot between the two, which is awesome. Thing is, my i7 imac FLIES with Corel in bootcamp and I am a corel main user.
So what I am pointing out to you Cx, is that you can buy another mac powerbook and you got the choice 😛
Your official Adobe licenses (i think corel also) will allow you to install onto two device. So you can use either for whatever purpose u want at the time 😛
u get me ? 😉
Last week my pc kept turning itself off and when i turned it back on it would stay on for half hour or so and back off again, bought a new power supply and everything back to normal now.
I had that problem before too…
and I had the overheating problem on a dell comp too…
this I am 98% sure was some sort of software prob…Ive yet to install cutter and versacamm yet…but it all looks to be running without a glitch on the install so far…fingers crossed…
the thing was running sooooo slow…I am glad that ive had to do something radical…the thought I’m paying for my lad to stare at a screen when nothing is happening or he has to keep restarting over and over…not productive..
Ive been looking at the macbook…oo Dave you are a tempter…it would be nice to have a lovely macbook…maybe the bigger one..? -
Looks like im off to buy a macbook…..
there has to be some bonuses from hours and hours of wasting my time!! 😀 -
Bought a hp… The mac was way overspec to what I needed… This was less than half the price…. Thanks Dave and everyone for the great advice..
Cheryl, bit late now but why a laptop?? You would really have been better with a small tower for that sort of work. Much cheaper to buy as well.
quote Martin:Cheryl, bit late now but why a laptop?? You would really have been better with a small tower for that sort of work. Much cheaper to buy as well.
handy to take with me if I need to…tis all
kin hate technology…
ever get to the point where you wonder if you are being had???
ho hum swig o rum… (drink1)
I know drinks not the answer, but it numbs the questions..and hopefully inspires the answer…
shouldhave bought a mac… -
Could be a windows seven versacamm problem… I can’t network either… Gunna have to sleep on it…
this thing sees my versacamm but doesnt send anything to print…went to install summacut and the cd reader doesnt even see it…
I know that the cd is okay as i installed it to another comp yesterday…geeze
I my knee jerk reaction is to take this hp back and go get an mac… -
I found an older cd which does work…summa wont run on a 64 bit version…
cannot seem to find a download on summa for a 32 bit or windows seven… -
Shoulda rename this thread as don’t panic…
Got cutter working.. Now printer 😕 -
You will probably need an upgraded Versacamm driver?
best of luck.
john
hhhooorrrayyy…got the printer working toooo!!!
now just for networking as I cannot get the mac talking to the laptop…
any ideas…thanks for putting up with me…this has been really painful…makes me all the more relieved..
quote John Thomson:You will probably need an upgraded Versacamm driver?
best of luck.
john
I woke up in the middle of the night thinking that…and you were right John
hoooraaayyyy…thankyou to the nerd on tube…got everything networked…
was a dark old place trying to get everything working…!!
should listen to positivity CDs again…!! -
Bit late I know but I eventually installed Versaworks on a 64bit win 7 PC as administrator, seemed to sort it.
