Home › Forums › Sign Making Discussions › General Sign Topics › Advice needed on stainless steel cut out letters, please?
Posted by David Bilton on 7 November 2014 at 13:34I was wondering what grade of stainless steel should be used for flat-cut stainless steel letters which are to be fitted outside.
Thanks in advance.
Katie Asken replied 11 years, 1 month ago 6 Members · 7 Replies -
I would leave that to your trade supplier / fabricator to worry about David.
If doing in-house i would get some advice from your sheet metal supplier. -
Thanks Robert. That’s what I like to rely on – good advice from suppliers, but sometimes you feel that more than one person’s opinion gives you a clearer picture.
Common to be using 316 or 316L
L stands for LINISHED ie brushed
quote DavidRogers:Common to be using 316 or 316L
The L stands for low carbon. 316L is generally used in the food industry. I would hazard a guess that 304L is the grade used for lettering.
quote Gary Birch:quote DavidRogers:Common to be using 316 or 316L
Good to know! That’s what I get for believing somebody else (engraving company).
304 for interior, 316 (marine & food grade) for exterior, but there is quite a difference in the cost. If you can, quote both options (and reasons) to the customer and let them decide. Basically the 316 will weather better outside than the the 314
The finish of the stainless is usually defined as BP (bright polished or mirror) or DP1 (brush finish)
Hi guys,
304 is external grade and 316 is marine grade.
We tend to use 316 grade if the sign will be within 5 miles of the coast due to the salty atmosphere.
If your sign is going outside (not near a coast) then I wouldn’t worry about the extra expense for 316 grade. As long as your customer gives them a good clean now and then there shouldn’t be a problem.
Katie
