Activity Feed › Forums › Printing Discussions › Printer Ink › Advice : Eco Solvent Inks
Posted by Adrian Neill on July 22, 2008 at 7:37 amMorning everyone ………
We run a Grenadier printer. It currently runs on Solvent inks. When it’s
working it’s a great piece of equipment, but it does need a LOT of upkeep
and most days we have a blockage of some description.Yesterday we received a call from some at Roland trying to sell us various
stuff. One thing he did mention was converting our Grenadier to run on
‘Eco-Solvent’ inks. Now apparently this will pretty much eliminate
problems with blockages and cut down solvent smells etc etc.The price mentioned to do the conversion was about 2k. Has anyone had
this done before ? Is 2k a bit steep ? Is Eco-Solvent ink really that much
‘better’ ??I think that’s it for questions ….. thanks in advance for any advice.
Phill Fenton replied 15 years, 9 months ago 10 Members · 12 Replies -
Good question and one I have considered myself.
However, what puzzles me is why the need to "convert" the machine? Surely it’s a beefed up version of it’s ecosolvent sister so should handle ecosolvent inks without any "conversion" being necessary?
I bought my Cadet under the illusion I could run it on either full solvent or ecosolvent ink – whereas had I bought the Versacamm it could only handle ecosolvent!
Does anyone have an explanation as to why Roland need to "convert" these machines back?
I can’t comment on the machine. But as for eco sol max inks we’ve never really had a problem with them.
Don’t have problems with our printers either in terms of maintenance. Wipe around the heads. the wipers and around the caping stations and I’m done.
talk to roland again i am sure that what they do is well worth £2k as i understand it , they change a lot of stuff that came in to contact with the solvent inks,
then they give you a full 12m warranty as well.
should inc 12 new carts as well.i think the cadet is £1k
i run eco sol max and as jason says its sorted
Do not pay for a conversion!!!!
I converted my Grenadier G2 last year to Roland eco max and I have not had a days problem with it since. You need to flush the system (£470.00 for flush carts 😮 😮 😮 ) and then just put in the new ink carts, If you read the manual it tells you how to change the settings on the printer panel to tell it what ink you are using. Overall it takes about two hours to do, I would recomend low users to switch from full solvent to eo-sol as your days of troubles will soon be behind you. Of course when you switch to carts your ink cost’s will rise quite considerably but you save on call outs and new print heads.Peter
Thinking about my last post, if you were to buy the flush carts and the new ink carts that would add up to about £950.00 so it looks like they are charging you about £1050 .Unless they are changing any other bits and bobs that’s quite a call out charge.
hi all
i have not long ago started using ecosol max inks in my cadet, spoke to roland and they said the same thing as they did to adrian, I asked why? they could not give a solid answer, just woolly claims about it has to have new pipes, heads, wipers etc. like phill i brought my cadet on the fact that it could run any ink. B&P have also stated on the boards that you can run any reputable ink in the cadet and not void any warranty, well i would say roland inks are reputable.
to that end i just flushed the ink lines and installed ecosol max carts, afew head cleans and all was well, less smell and if anything the prints look a bit more vibrant. as has been said before elsewhere the durability is about the same.
I am not saying what roland do for the money is not worth it but do question the need to do it.
Paul
I have just had the Roland conversion to eco sol on my 4 year old Cadet +. The reason I did it was the fact that one of the heads had drop out so I rang for a price on a new head which was £600. They said that for £1200 they would replace both heads, dampers, pipes, scan motor, circuit board, all pipes and the carrier wire. It also included all new panels with the Roland logo… but the main selling point was that they gave me a full 12 month warranty on a 4 year old machine!! I know the carts are a little dearer but at the end of the 12 months I will put my bulk feed system back on and use after market inks. I have to admit I am Very happy with the results
Ian
Sounds like a very good deal when you put it that way Ian.
I’ve been wondering what I’ll do when it’s time for a head change, I’d certainly consider that.
Basically a new printer for £1200 + Vat.I’ve also been thinking of changing over to the max inks but I was just going to flush and fit the new inks.
There is no conversion needed to run ecosol on a Uniform printer, I belive Roland take the printer back to how it was as much as anything to stop you being able to return to full solvent to easy.
The Roland deal in my opinion is great if you have a printer that needs new parts as these will be supplied and warrentied, however if you just want to change to ecosol inks because you have blockage problems etc then as said this is a strightforward ink change that you can do yourself.
I think Roland have missed a trick here as the reason for the above deal is to get you back to buying there ink, selling you a printer is good money but the real value is in the onging revenue from the consumables, i think Roland could sell a lot more ink especially for use in the Uniform brand if they produced ecosol in bottles so you where not forced to use carts.Regards
Russell.
Remember to change the dampers…but you are right – flush the pipes properly with solvent flush and with ecosol flush, change the dampers and you are sorted 😀
Steve,
What is it that the dampers do, and where are they on the machine?
Sam -
The dampers are fitted at the ends of the tubes that supply the ink to the heads. They are fitted just above the heads – there is one damper for each colour.
I’m not sure of their purpose but think they are there to prevent fluctuations in pressure and flow of ink into the heads.
