A Graphtec CE 5000-60 Contour Cut using Corel Draw x4
I have watched many tutorials on this subject but I have never had any success cutting around a contour so I started to play around and come across my solution and this works for me so I hope it will also work for you.
Open your cdr file
Make to size required using the pick tool
( Try to keep image in centre of page)
Make sure image is grouped together
Then use the Interactive contour tool (set contour to say about 1.5 mm to 2.00mm)
Change contour fill colour
Arrange –Break contour apart
Then place on your registration marks using Cutting Master use( Type 2 Automatic)
Do not put a tick in convert rectangle
Print off your file in the printer
Then Place the printed image such as your Transfare paper on another spare piece of vinyl (this is used as a backing piece so the cutting blade doesn’t cut into the Graphtec bed
Select your image so it is highlighted
Then cut/plot
When Cutting master starts click on properties and select only the colour which you choose to be you contour outline colour
Place your printed image with is carrier backing on into the Graphtec and choose Sheet
Place the cutter in the middle of the bottom right hand side reg mark
Send
OkAnd this should make the Graphtec cut around your image.
