Riviera (4980cm x 4320cm) how to do big mesh’s (TUTORIAL)
Hi i would like to do some tutorials. I’m started with biggest Polish Mesh’s called Riviera, which situated in Warsaw. The format of the mesh is: 49.8m x 43.2m. Project has a 4 tunnels situated on the back at distances 1.10.5m, 2. 10.8m, 3. 7.2m, 4. 10.8m, 5. 10.5m (u can see it at specification = 4.jpg). Tunnels around, and eyelet in each of connecting panes. Strengthened corner tables from warm with triangles from full vinyl, fully eyelet too.
INFO OF PROJECT: ~ 4.jpg
MATERIAL: MESH
LENGTH: 4980cm ~ 49.8m
WIDTH: 4320cm ~ 43.2m
TUNNELS: 4 when each tunnel has 30cm x 4320cm ~ (25cm they want + 2x 2.5cm on the warm at other sides = 30cm)
1. We must do the tunnels.
For the first, we get a end of roll of mesh about 18m. We have developed in the hall, measure tunnels, cutting mesh and we take up for their connections. So we cut 12 lines about (30cm x 1500cm) then we must warm 3parts to 1tunnel (3x 30×1500 ~ 30×4500). Be sure u have good temperature at your warmup, because too high its burnt material, next too weak warm maybe to let go and net was disperse on the elevation..
on sunday we warm up the mesh, then i will upload more photos at the job. do i the write the post good?? please correct me if i posted some wrong. greetings!!
