Hexis & Duo Display Systems
HEXIS ANNOUNCES EXCLUSIVE UK DISTRIBUTION AGREEMENT FOR DUO DISPLAY SYSTEMS
Sign vinyl and digital print media specialists, Hexis UK Ltd has announced that it has reached agreement with Duo Display for the exclusive UK distribution of Duo portable, pop-up, roll-up and banner display systems.
Duo systems are now available in kit form for sign makers and digital printers to design and produce point of sale, mobile marketing, merchandising and exhibition displays. With its existing ranges of printable polyester media, therefore, Hexis is now offering several different combinations of display system hardware and print media for next day delivery, where required. The Hexis range of pop-up and roll-up printable media is suitable for all printers on the UK market so that print ability can be guaranteed.
There are several products in the Duo range, and all are light weight, easy to set up and use. Hexis will focus, in particular, on the Duo.blue, Duo.Xpressions and Duo.sprint systems.
Duo.blue is a pop-up, panel based, system featuring a self-locking, ‘umbrella’ frame with connecting magnetic bars for applying graphics. It is available with a curved or straight, cross braced frames and in a range of widths and heights up to a maximum graphic height of 2.3 metres. Duo.blue comes with standard accessories such as lights, headers, interior or exterior shelving and folds away into a wheeled, rotomoulded container.
Duo.Xpressions is a development of the Duo.blue system, designed to carry fabric and special textile media graphics. It features the same frame system and can be used in both straight and pyramid structures to produce tailor-made displays. Graphics are applied to a back lit polyester fabric panel and each panel is then secured to the frame with eyelets and rings. Straight structures are available, as standard, up to 2.3 metres wide x 2.3 metres high and pyramids up to 3.3 metres wide x 2.2 metres high.
Duo.sprint is a banner display system which uses a telescopic pole to reach heights of 3.0 metres.
There are four standard widths up to 120cm and the height is adjustable. Single or double-sided graphics can be displayed on the same frame using rigid or flexible substrates. Duo.sprint has brochure holders and lights accessories and folds away into a carrying case.
Responses
