Home Forums Vinyl Cutter Discussions General Cutter topics Wrong parameter problem with roland pnc. parallel or serial?
  • Wrong parameter problem with roland pnc. parallel or serial?
    Posted by Alistair.Cunningham on 11 December 2006 at 18:54
    [/url][/img]
    I’m quite new to all this so i need some help.
    I’ve got an old roland camm pnc-1000 and i’m running it with flexi from ibm thinkpad laptop.
    I managed to get it working using a parallel cable from the laptop to the cutter, but now and then (too often) i get the message " too many parameters or Wrong Parameter" and the cutter goes spazzy and cuts up half my media.
    Do i need to swap to a serial connection?
    Which port do i use? *See Pic
    The port on the left with the funny symbol is 9 pin and the one on the right(serial?) has 15 pins.
    Once i have a new cable,
    What do i need to change in the settings on my PC / software??
    Please Help!!! (hot)
    Ian Stewart-Koster replied 18 years, 10 months ago 6 Members · 8 Replies
  • 8 Replies
    11 December 2006 at 19:15
    hi
    your 15 3 row pins should be a vga output the 9 pin 2 row is a serial in – out.
    if useing lpt1 then there is a option in the computers bios to change the type of paralell output sorry cant remember the exact one you want for this older cutter as this sounds like a buffer problem.
    11 December 2006 at 19:26
    Does Flexi allow you to "spool" your output to the plotter? If so, try it. This may solve the problem using your existing cable and connections
    11 December 2006 at 20:44
    If you run flexisigns production manager utility and enter "setup" tab "setup properties" – tab "Communication" you can set a buffer for your cutting output from 128 to 2048 bytes. I would try setting the buffer to as high a setting as possible (i.e. 2048)
  • Alistair.Cunningham
    12 December 2006 at 17:40
    😀 Thanks Guys
    I put the buffer rate right up and it’s solved the problem!!
    the old girl is running like dream.
    Thanks again for your quick replys.
  • Adam McGuire
    14 December 2006 at 16:53
    I’ve had this problem too….I’ll try changing the buffer later.
    Another thing I get sometimes is it cuts a load of letters and number….usually seem to start A4……..
    And then occasionally, the cutter just stops mid job then a few seconds later, lifts the blade and won’t go any more. I have to cancel the stuck job in production manager then throw out the vinyl, and start again.
    Any ideas on these anyone?
    Adam
  • Bob Jones
    14 December 2006 at 23:00
    Does anyone know if a test cut on the pnc1000 can be done and if so how do you do it (I have no user manual)
  • Adam McGuire
    15 December 2006 at 00:08
    If it’s anything like my PNC-1210, I think there’s an application you can download from Roland DG to test it. If I remember correctly, there’s an option in the menu on the cutter itself. I think it cuts a cross or something similar.
    I’ll have a look tomorrow if you don’t find it!
    Adam
  • Ian Stewart-Koster
    19 February 2007 at 03:35
    Testplots: hold the uparrow pressed, then switch the plotter on.
