Wrapping over a panel weld/joint – Advice
Got a fleet job at the moment, just discussing the best way to handle the weld down the side of the van.
The attached visual shows where we’re apply the graphic, the branding we’ve removed had the vinyl slit either side of the weld.
We’ll be using Oracal 970… it would look better without a white line down the side… on the other hand I’m not 100% sure it wont fail.
I’ve done a few tests today with a van of theirs, and I’m not convinced that we can get all the air out down the weld, resulting a failure. It’s not helped by the fact the weld’s not perfect, there’s a big ‘blob’ in the recesses which complicates things.
Any techniques you could suggest, or would you just slit the vinyl?
