Home Forums Sign Making Discussions Vinyl Wrapping acrylic tube – Help
  • Wrapping acrylic tube – Help
    Posted by Paul Munford on 25 September 2012 at 13:41
    Hi All,
    I have been asked to wrap some acrylic tubes 2400mm long x 300mm dia. in a mirror gold vinyl.
    My question is what is the best way to apply this? How would you do it? stand the tubes up vertically and work the vinyl round or lay them flat on a bench? would you apply dry or wet..
    Hoping for any pointers / tips. 😕
    Steve Maple replied 13 years ago 5 Members · 5 Replies
  • Kev Mayger
    25 September 2012 at 14:21
    I think a trial and error approach would be best. Try a smaller area dry to begin with and see how the material behaves.
  • John Harding
    25 September 2012 at 20:49
    I wonder if you placed a piece of vinyl on a bench adhesive side up and rolled the tube accross the vinyl if it would apply itself neatly and uniformerly – seems too easy but I would try 😀
    25 September 2012 at 21:12
    lay vinyl on top of tube and work the lenght squeeging along while turning over and do it dry , wet might get you into bother with gathering and not laying on properly but as kev has mentioned try all methods out 😀
    26 September 2012 at 04:52
    I would have a trial run before committing yourself to the job. Are you talking about vinyl or polyester film as well because most of the mirror chrome & gold materials are not vinyl. Polyester film is a little different to vinyl when it comes to fitting which is why I suggested a trial run.
  • Steve Maple
    29 October 2012 at 15:59
    I have doe this before.
    1st you have to pre cut gear so size leaving a inch for the long joint overlap
    plus half inch each end to trim – if you go a bit squiffy
    2. you have to apply application tape to the mirror gear, as one it will stiffen it up and two, if you don’t you will scratch the grandmother out of the job.
    3 after you have covered your pre cut panels, mark the centres at the end, don’t however strike a line right the way through or you will see it in the finished job
    4. lay the tube flat on the floor, put a bubble on it to find the tops at ech end – mark the tops each end on the end.
    5. flip the mirror over on the bench and tear out a 6 inch strip through the centre
    6. all you need is a light dust of soapy along the top.
    proceed to apply one half, then the other.
    p.s. if you try and do it in one hit from one side, all the way around and you are a few degrees off, – by the time you get all the way around you might run off
    doing each half, halfs the error, plus you minimise the risk of creasing the gear
