• Wonky letters?
    Posted by Jill Marie Welsh on 20 November 2009 at 22:19
    OK here’s my first complaint about my new plotter.
    (Graphtec CE5000-60) Running on Cutting Master 2 1.60 and designed in Corel 12.
    I am totally used to GA 6.2 and Omega 2.02.
    I didn’t trust Corel for proper sizing so I converted to curves, imported as AI to Omega, re-sized, out as AI then into Corel and out to the plotter.
    As you can see, the letter quality is just awful.
    (Pic 1)
    The letters I typed directly into Omega and imported to Corel 12 are fine.
    (C in Pic 2)
    I do not think I will be able to use these poorly cut letters.
    Any recommendations? I know I am doing things back-assward.
    They weed OK, just look like crap.
    Thanks.
    Alan Drury replied 16 years ago 13 Members · 22 Replies
  • 22 Replies
  • Karl Williams
    20 November 2009 at 22:21
    Won’t G.A or omega run your cutter?
    20 November 2009 at 22:28
    sorry jill can’t see well enough.
    corel sizing can be a pain but if converted to curves the the sizes shown are the max x y dimension.
    bigger pic taken square on will help
  • John Singh
    20 November 2009 at 23:41
    Can’t think it to be the plotter especially Graphtec
    You say you can’t trust Corel for sizing but have you sent from Corel direct to see how letters cut (even if it is the wrong size what do the letters cut like?)
    20 November 2009 at 23:48
    I will have to try it.
    I’d upload a bigger pic but on this part of the forum you can’t add pix and Photobucket won’t let me go bigger.
    I know I am doing something wrong.
  • John Singh
    21 November 2009 at 00:03
    Can you get into the sign software forum under Corel
    I’m sure it discusses something similar (around Oct 18 thread)
    21 November 2009 at 00:07
    I will check it out.
    The main reason (besides the not trusting sizes) to go to Omega is that when I do an outline in Corel it adds about a million extra nodes.
    I did know how to fix that at one time but I have since forgotten.
    Sorry for being such an idiot!
  • Karl Williams
    21 November 2009 at 00:27
    I’ve tried it by exporting from coral x3 as ai version 3. Imported to omega
    re-sized…imported into coral..no problem. Not that many nodes.
    If you generate a small text sample and export it..resize it then export back
    this can make the curves go crappy.
  • Otto Peltonen
    21 November 2009 at 08:48
    quote Jillbeans:
    Making an outline and converting it into curves in corel can be pure pain, but make a contour instead, works much much better.
    21 November 2009 at 09:15
    Hi Jill the picture is not clear enough for me to see the problem I’m afraid but general info as follows:
    Sizing, Corel sizes letter in the normal typographical manner ie it takes into account acenders and decenders – fine for printers but a PITA for signmakers who require a 20mm cap to be 20mm. There is a couple of solutions, not necessarily ideal but a workround.
    Type your text (Artistic)
    Type in another text string (Artistic) a letter H or other letter with no curve.
    Size this H to desired cap height using the object size box and note point size.
    Change original text to that point size
    OR and this applies to X3 and X4, I’m not sure it works with versions before goto http://www.macromonster.com and get the Autosize macro, about $9.99 – £6.50ish. This allows you to draw a line from top to bottom of your text string, then select the line and text, run the macro and type in the desired cap height – and then everything is sized to that.
    Outline X3 and X4 uses beziers for contours/outline so the issue of lots of nodes is sorted.
    X3 and X4 is a significant improvement over V12 and I would consider an upgrade if you intend to use this as your primary design software. Macromonster now has macros to enable cutting direct from Corel, nesting and power weed or if you prefer Omega export from Draw as AI say V4 – deselect the ‘simulate filled curves and select the ‘export text as curves. This will avoid construction lines through the letters and retain text as text in your Corel document but make it curves when in Omega.
    21 November 2009 at 12:37
    hi jill
    ive temp moved your post to allow picture attachments. not a problem…
    ill move it back once we find out how to solve your problem.
    please rest assured, it is not your cutter causing this issue. ide bet my bottom dollar its not. :lol1:
    i cant help on the software issues as i don’t run any of those mentioned, but what i will say is your process of exporting, importing etc all sounds a bit long winded to me and probably somewhere is corrupting your file.
    21 November 2009 at 12:44
    Thanks for the temporary move!
    That vinyl has since been masked (that’s a whole nother story)
    so therefore would not be easy to photograph.
    I called the client last night and delayed the job for a few days to get this sorted, even if it means upgrading Corel.
    Please remember that as sassy as I am with layouts, etc., I am that stupid when it comes to computers.
    I know it’s the import/export at fault, not the plotter.
    They were typed small then resized in Omega.
    Thanks for helping.
  • Karl Williams
    21 November 2009 at 13:37
    Sometimes when you export small text in coral to omega the nodes seem to crunch up together and move the vector lines and curves Jill.
    The sizing in coral to cut shouldn’t be a problem as as far as I can remember I’ve never had an issue with this.
    As Rob said, It won’t be the cutter.
  • Graeme Harrold
    21 November 2009 at 14:05
    Its going to be the export filter messing things up. I use the same process for engraving. Create in Corel, export as an Ai then import back in. The problems I get are paths that were closed are broken into parts, duplicate outlines superimposed etc. Try some different filters e.g. plt or dxf
    Or just cut direct from Corel…. :lol1:
  • Paul Humble
    21 November 2009 at 14:11
    I cut from X3 via cutting master 2 and get none of these probs.
    21 November 2009 at 14:12
    Graeme, deselecting ‘simulate complex fills’ should sort that problem.
    Jill I have known very small True Type text exported to corrupt in early versions of Draw. I noticed this when doing litho work so it was very small. I have not noticed it with sign work where the letters are not often smaller than 1 inch and I’ve never noticed corruption in X3 or X4. What size are you talking about and I’ll try it.
    Alan D
  • Tim Painter
    21 November 2009 at 15:12
    I don’t see working direct from Corel as an Issue at all, I can see all the import / export causing issues and extra work.
    Here I’m working with ver 12 and cutting straight to my Roland.
    Text converted to curves and outline set to 0.1 point.
    Some founts are lousy but I have not seen it as bad as your pic Jill.
    Do you cut direct from Corel to the cutter or via a plugin?
    21 November 2009 at 15:36
    OK the "Straight" pic is typed directly in Corel. Font is Impact.
    Size is 1.76" high.
    (I forgot to note the length but it’s 24 points on an 8½x11 inch page)
    "Imported" pic is the font after being exported as an .ai to Omega and sized to a length of 40". Then imported as an .ai back into Corel.
    See the weird edges? This is the file I cut.
    I know I am going to have to learn a different way to do this.
    An upgrade to X3 is only $50 now, and seems more straightforward (I think) with the sizing. Or should I say the lack of trust I have!
    hahaha
    I am such a control freak!
    I will have to be careful with all my old files if I ever have to cut new jobs from them.
    And someone is kindly giving me a Weber tool so that should help with my masking issues.
  • Mike Fear
    21 November 2009 at 19:00
    Theres something odd happening when its being imported into Omega.
    Impact is a pretty smooth font compared to some, and doesnt have many nodes so your letters should have nice smooth curves.
    If you type the text you want in Corel, then convert to curves you can scale it to any size ( big or small ) and it wont add any extra nodes to the letters.
    Are you exporting from Corel as a vector file ? from your pics it looks like the text has been exported as a bmp, then Omega has re-traced it with some sort of auto trace and made it come out rough.
    As long as you export from Corel as a vector, and convert the text to curves before exporting, then you should end up with exactly the same thing in Omega when you import it as a vector.
    I would check the settings for your exporting in Corel and importing in Omega to see if there is something that is making it convert it to a bmp somewhere along the way.
  • Mike Fear
    21 November 2009 at 19:03
    Forgot to mention !
    If you can cut directly from Corel, do this rather than exporting, re-sizing and importing back.
    As long as you make your text, then convert to curves and then resize it, the size will be correct when you cut.
  • Simon Clayton
    23 November 2009 at 00:53
    By the looks the file its being corrupted when importing back into corel, can you not try importing in a different file format. I’m sure this used to happened to me, in AI so moved over to EPS
    I can’t remember having sizing problems in 12, the way i used to do it was, if i wanted 1" letters i would draw a 1" box and just enlarge the letter till it matched the box..
  • Duncan Wilkie
    23 November 2009 at 01:06
    We plot directly from Omega to our Graphtec plotter. The drivers come with Omega It’s an awesome combo. You said it was a new plotter, so I take it for granted that it is supported by Omega?
    23 November 2009 at 17:43
    I am fairly certain that the issue is the size of export as 24 point is very small – with a letter size at about an inch (72 point) or preferably bigger and I would expect the curves to be smoother.
    Alan D
