Home Forums Sign Making Discussions Vinyl wondering how would you apply vinyl over this sort of curve?
    28 November 2006 at 12:03
    Ideally, you’ll need to use a cast material, and probably heat it into the indents, as well as shrinking the excess over the apex.
    I think this is a wrap tho, but you could do it easily in computer cut. The biggest problem would be not strecthing it out of shape as you go over the roof.
    Take your time, tho.
  • Dennis Van Der Lingen
    30 November 2006 at 14:44
    for concave area’s you normally apply the vinyl until the stress in the vinyl will cause wrinkels in the next stroke, then you heat the entire piece until the stress dissapeares, you the recomence until there is again to much stress, heat again, and repeat the process,
    if it’s a wrap it’s easier, just applie until the concave area, heat the remaining piece of vinyl and with both hands pull the vinyl over the concave area while spreading your arms apart so you opening the vinyl while stretching it, much faster, much easier, just practice and you’ll get it
  • Jason Xuereb
    11 April 2007 at 13:49
    thanks for the tip dennis.
