Home Forums Sign Making Discussions Vinyl Windows graphics advice please?
  • Windows graphics advice please?
    Posted by Phill Fenton on 28 April 2004 at 07:54
    A/ Best to use Oracal 751 series which you can get from Europoint display 😕
    B/ If you do a ‘Rob Lambie’ special and make it one way visible (using the two mm strips) this may or may not cause issues with the windows going up and down, I don’t really know. 😕
    Yes….some vehicles do have windscreen wipers on the rear windows. This is to er…….. facilitate the wiping of the rear windows 😕
    David Arch replied 21 years, 7 months ago 1 Member · 1 Reply
  • 1 Reply
  • David Arch
    28 April 2004 at 08:07
    If you are putting vinyl onto windows that will be wound down I would suggest that you remove the outer seal and place the bottom edge of the vinyl below where the seal would be and then replace the seal. Hope that makes sense.
    The reason for this is that the seals are normally quite tight and would soon start peeling almost any vinyl from the window.
    As for rear windows, jst dont use the wiper and if you are worried you will use, remove it completely.
