Wind loading – structural advice required??
Hi All
Please see attached a design which has been approved by the customer and informally by the planning officer, however, just getting second thoughts about whether or not this will be strong enough – ie, wind loading etc.
The overall width is 2.75m, post height above ground 3m. The posts are 6" square section timber pre-treated from the timber merchant and we’ll treat them at least 2 more times. The lower 9 panels are modular and will be changed with tenants – we have left gaps between them for visual appeal and to reduce wind loading. The sign is double sided – looks identical from both sides, panels are 4mm dibond. Posts will be at least 1m into 2′ dia ground sleeves that are will have substantial conbcrete around them. We’ll insert into ground sleeves and top up with concrete.
Anyone have any comments on whether from experience this structure is likely to stand up to strong winds?
*** We have a second similarly sized job but with Ali posts – Ashby kindly calculated that it would be OK with 114mm dia posts, so seems 6" square wooden ones should be strong enough for this one.
Many Thanks
MackyCheers
Macky
