Home Forums Sign Making Discussions Neon, LED, Lighting wind load on this?
  • wind load on this?
    Posted by Myles Brewer on 27 January 2012 at 12:59
    Hi all,
    Just wondering if a single, thick wall, 76mm dia galv steel post would be sufficient for mounting 2 qty 610mmx2200mm aluminium signs (portrait) onto with 6 pieces of channel on the back of each? bottom of signs 1.2m from ground & 1m of post below ground in concrete.
    Myles
    Myles Brewer replied 13 years, 10 months ago 7 Members · 10 Replies
  • 10 Replies
  • NeilRoss
    27 January 2012 at 13:57
    Am I reading this correctly – 2 @ 2.2M high panels on one pole?
  • Myles Brewer
    27 January 2012 at 14:24
    Hi Neil,
    Yes, that’s correct, one either side & not one above the other though 😮
  • David Rogers
    27 January 2012 at 14:26
    So – top is 3400mm out of ground, 610mm wide x 2200mm high.
    1m in ground, concrete in (and use LOADS of it).
    YES, the pole will be strong enough but it will flex and vibrate quite a lot in the wind.
    Two poles better.
  • NeilRoss
    27 January 2012 at 14:29
    quote Myles Brewer:
    Hi Neil,
    😀 OK – I’d go along with what David says then.
  • Myles Brewer
    27 January 2012 at 14:38
    Thanks Dave / Neil, I wasn’t sure if at that width it would be necessary to have 2 posts, but best to be safe I guess.
    Myles
  • Steve Morgan
    27 January 2012 at 14:44
    I suppose I have to say that if you use the following figures I will not accept any responsibility, however they might be a useful guide. An old friend of mine, an engineer involved in the design of building structures replied to the same question I asked of him a couple of years ago as below:-
    Steve,
    Its more complicated as you might guess, depending on location surface surroundings and life expectancy.
    A good rule of thumb for general conditions would be 0.75kN/sq.m (15lbs/sq.ft in old money).
    Hope this helps
    Barry
    Subject: Wind loading
    Barry,
    When you work out a figure for wind load /m² or ft² do you use a chart or is there a constant that can be multiplied by the wind speed? Or is it much more complicated than that?
  • Gary Birch
    27 January 2012 at 15:22
    An in between would be to us an 89mm post?
    Gary
  • Peter Dee
    27 January 2012 at 16:18
    If you’re registered with the Ashby website they have a wind loading calculator tool on the site.
    27 January 2012 at 18:22
    depends who you use as a supplier, I use to use Ashby for this sort of thing and would just tell them what size panels I required at what height above ground. They would calculate the post sizes required & number of runs of channel as they had the tables to do it.
    If Peter says the tables are on their site though you may well be able to do it yourself.
  • Myles Brewer
    8 February 2012 at 11:27
    Thanks all for your input, I’ve registered with Ashby now & their calculator reckons 76mm is ok but I think I’d use 2 to be sure, being that it gets a might breezy here in the West of Ireland 😮
    Myles
