Home › Forums › Sign Making Discussions › Vinyl › will vinyl stick to painted ply board?
Posted by daniel day on 24 October 2007 at 17:03Hi People
Your help would be be greatly recreived. I am sticking vinyl to painted ply board, i have used water and oil paint, varnished it, used heat and still the problem. I have seen some boards done and the seem to use a type of clear sealer and the vinyl stick like mad to theres Can anyone help
P.s the vinyl used is mactac both types
CheersDan
daniel day replied 18 years, 1 month ago 6 Members · 12 Replies -
has the board been sanded down, then given a good gloss coat?
if its smooth and a decent "gloss" coat. there shouldnt be any issues… none i can think of off hand anyway… mactac 3-5 and 5-7 year range would be perfectly fine to use.
are you fitting the vinyl wet or dry?
fitted dry, it seems to stick for a while and then starts to peel
sounds odd Daniel, what if anything are you using to prep the board before applying the vinyl?
You say you have used both water and oil paint.
Are you referring to Latex paint?
I can never get vinyl to stick to this well, even with a dry application.
Especially with MacTac.
You might try heating it with a hair dryer and burnishing with a felt squeegee.
But I doubt it will help.I would remove the vinyl, clean and sand the board, and paint it with 1-Shot lettering enamel. Wait two days, then try Oracal 751 applied dry.
You could probably varnish over this with 1-Shot speed dry UV clear to insure adhesion, but it’s not usually necessary.
Love….Jill -
Now – importantly, is it VARNISH or clear polyurethane (PU)?
Not much sticks to real varnish…and you can unfortunately get some PU clear coats that contain such oddities as Teflon (non-stick).
I’d normally just apply straight to the paint. And it probably work best with a non-‘trade’ (often a lower oil content for domestic market) type & (although it’s not required) I’ve known it to be clear coated in yacht varnish (PU) for a pick-proof & even gloss finish.
What IS required though for best adhesion is a flat surface without the grain being prominent…or it’s out with the heat gun & dabbing the softened vinyl into the grain!
Best way to coat plywood is:-
1. 2 coats of oil based primer.
2. 2 coats of oil based undercoat.
3. 2 coats of top coat gloss finish.Sand down between each coat starting with 120 grit then 180 and finally 240 grit and thin the first coat of primer about 20% with white spirit.
Paint using a 4" wool roller and switch to a foam roller for the top gloss coats.
I wouldn’t bother with varnish as this yellows after 18 months to 2 years and DO NOT use polyurethane varnish outdoors.
I use 1 Shot Sign Restoring clear and have never had any issues.
If you follow this procedure you should never have any adhesion problems.
Hope this helps.
Neil
