Home Forums Sign Making Discussions Vinyl Will vinyl stick to Galvanised Steel
  • Will vinyl stick to Galvanised Steel
    Posted by Matthew Greer on 22 September 2009 at 18:23
    Hi all i have got a job on that requires vinyl sticking to some Galvanised Steel boxes, They are going to be white blocks of Vinyl with lettering on them.
    Will vinyl stick to them ok?
    Cheers for the help.
    Hugh Potter replied 16 years ago 5 Members · 5 Replies
  • Craig Newton
    22 September 2009 at 18:27
    GOOD QUALITY VINYL AND ID WARM THE STEEL BEFORE APPLICATION AND ROBERT IS YOUR MOTHERS BROTHER!!
    doh sorry bout caps 😳
  • Matthew Greer
    22 September 2009 at 18:32
    Yeh was thinking about warming it first with a heat gun, unless its a nice day but a very much doubt. Will be using Avery 600 or 700, not sure yet.
    22 September 2009 at 18:39
    you dont need to warm the the steel as long as it is clean it is the same as any other substate
  • DaneRead
    22 September 2009 at 20:51
    Hi. U need to get a galv prep chemical. You should be able to get
    this from a paint supplier. This chemical takes out the oil that is left in the galvanising process. Then u can just use the normal vinyl surface peperation chemical like isopropyl and just apply away. It really needs that chemical that takes the oil out if the sheet. They use this chemical before they paint galvanised sheet. I can’t remember the name.
    23 September 2009 at 06:44
    i clean with solvent thinners, wipe over with regular app spray type cleaner and apply, have yet to see a job fail.
    HUgh
