Home Forums Sign Making Discussions Neon, LED, Lighting will steel self drillers attatch a banner to wall?
  • will steel self drillers attatch a banner to wall?
    Posted by Deleted User on 1 June 2005 at 09:49
    Hi everyone, wee bit of advice needed please. Im fitting a light duty banner wall mount system to a free standing 150mm square pole. The pole is made of steel, do you think steel self drillers will do the trick (tho they are really ugly) or can anyone think of a better method which is more visually pleasing?
    Thanx again
    Peter Normington replied 20 years, 6 months ago 6 Members · 10 Replies
  • 10 Replies
    1 June 2005 at 10:02
    Large flat head rivets may look better.
    People like commercial body shops or Brown brothers will stock them.
    1 June 2005 at 17:17
    not sure if we are thinking same thing but ide use tech bolts. (tight threads for steel)
  • Deleted User
    Deleted User
    1 June 2005 at 17:24
    are they the same as tak screws robert, sort of ugly self drillers that you can also get for wood and aluminium?
    1 June 2005 at 17:34
    sounds same mate, have a head on them with metal washer with rubber ring below. you need a special adapter for your drill to hold them?
  • Deleted User
    Deleted User
    1 June 2005 at 18:26
    aye thats them, prob will use them, we call em tak screws. only thing is they are real ugly
  • Bill Dewison
    1 June 2005 at 18:47
    I saw a rubber cover thing for those, can’t remember where I saw it though… probably a freebie catologue thing that came to the shop. Not much help am I? I’ll shut up now 😳
    Cheers, Dewi
    1 June 2005 at 18:55
    yeh we have the covers too dewi, got them in about 5 colours. last ages coz you have to buy about 500 at a time. to be honest i think they actually draw more attention to the fixing even though they are coloured coz they make them look bilkier?
    if i have to use them but want to hide as much as possible ill spray the heads then fix.
  • Marekdlux
    We get screw covers from a company named Kompan. They make playground equipment. The covers are great for certain applications, not sure if it would be right for this though.
    -Marek
  • Brian Maher
    1 June 2005 at 22:36
    hi david,
    we use the tek-screw with covers too..
    you could try a local steel works…
    the guys near us use the coloured caps on the tek-screws for erecting cladding on sheds and warehouses etc. to hide the screws….
    good luck
    brian
    1 June 2005 at 22:46
    Ok if you really want to do a good job,
    use countersunk machine screws, and drill and tap the steelwork.
