Home Forums Vinyl Cutter Discussions Roland Cutters why wont my pc60 print and cut not do both together?
  • why wont my pc60 print and cut not do both together?
    Posted by ianh on 14 June 2007 at 09:28
    recently bought a pc 60 cutting great and printing fine i can set up the contour cut etc but when i send it to print then cut as separate jobs it comes back ripping then error
    have i gone a setting wrong as i have printed things off test cuts etc
    Chris Wool replied 18 years, 6 months ago 2 Members · 5 Replies
    14 June 2007 at 14:51
    what software please dont understand this
    quote :
  • ianh
    14 June 2007 at 15:02
    hi again chris i am using flexi sign pro 6 sorry it would have helped if i had said tha in first place
    14 June 2007 at 21:12
    dont know the software but you should have the options.
    print only
    cut only
    print & cut
    possibly cut then print but don’t use it.
    if set to print & cut it should print as required then wind back to the start then cut.
    with the roland driver you can print then cut as 2 separate operations.
  • ianh
    14 June 2007 at 21:39
    hi chris this is the option i have selected as 2 seperate operations it put a registration mark down but when i send it to production manager it displays error i think it is in the settings myself but just a matter of locating it
    14 June 2007 at 21:51
    the pc60 does not understand reg marks you can only reset the origin.
    so not sure what you are trying to achieve
    Chris
