Home Forums Software Discussions Signlab Software why wont my files load from the cadlink disk?
  • why wont my files load from the cadlink disk?
    Posted by Brian Little on 9 February 2005 at 11:41
    can i just add to that ….for some reason it wont open folders that ive used antol_cp on……its in the comp i know it is …it wont even load the file from the cadlink disk …im lost …help !!!!!!
    Regards Brian 🙁
    Brian Little replied 20 years, 9 months ago 2 Members · 2 Replies
  • Frank Droog
    9 February 2005 at 14:53
    Does the cd have a scratch?
    Is your CD rom drive dying.
    Can you copy/paste files from any CD to you harddrive to test your drive.
    Are you accesing fonts off of the CD or the harddrive?
    If the font is on the harddrive, delete it, and reinstall it.
    Double check that its not 0 bytes in length after you reinstall it.
    frank at cadlink.
  • Brian Little
    9 February 2005 at 16:00
    Thanks a million Frank!!!!!!! …that worked perfectly
    Regards Brian 😀 😀 😀 😀 😀
