Home Forums Software Discussions Flexi Sign Software why wont graphtec 3000-60 & flexi problem cut properly?
  • why wont graphtec 3000-60 & flexi problem cut properly?
    Posted by Ray Leone on 19 February 2006 at 19:14
    i’m currently running flexi 7.5 w/ a master vinyl plotter. i’m looking to upgrade my plotter to a graphtec. my friend has a graphtec ce3000-60 running on corel 12. the problem is, when i installed my flexi software on his computer it only cuts a bunch of random, openline numbers & letters(not what’s selected to cut). it cuts on corel fine, he has it connected to the computer via USB, could that be the problem? or could there be a conflict between flexi & corel?
    jeffus – Graphtec replied 19 years, 9 months ago 3 Members · 3 Replies
  • Phil Kneale – Graphtec
    20 February 2006 at 07:24
    HI Ray,
    The Graphtec runs in two different languages, HPGL and GPGL. It sounds like your friends Graphtec is set up to run in GPGL.
    Flexi only works in HPGL. IF you go into the menu’s on the plotter and find the Interface settings, you can switch it to HPGL
    Phil
  • Ray Leone
    20 February 2006 at 17:56
    o.k. that makes sense, i’ll give it a try. does corel have to be ran in GPGL or can it be ran in HPGL also?
  • jeffus – Graphtec
    22 February 2006 at 15:40
    Hello,
    Corel Draw using the Graphtec windows driver has to be run in GPGL,
    Flexi HPGL,
    Jeff
