Home Forums Printing Discussions Mimaki Printers why is the mutoh (Jetster) drawing blue lines please?
  • why is the mutoh (Jetster) drawing blue lines please?
    Posted by Tomas Vidziunas on 1 October 2008 at 09:22
    Hi all,
    I have a few questions about printer Mutoh SDMP-82E (Spandex Jetster).
    When you print something the beginning is OK, but after some time it start to draw/paint 🙂 blue lines that are not suppose to be there.
    For example if you print a map and a lake is blue and white area around it starts like stretching that blue from lake. Later it does just simple starts to draw lines every pass everywhere.
    I heard that it can be because of low temperature?
    Maybe someone knows how to "fix"?
    Hope you understood what I wanted to ask 🙂
    Thank you.
    Tomas Vidziunas replied 17 years, 3 months ago 2 Members · 2 Replies
  • Mark Elvidge
    1 October 2008 at 16:15
    make sure that all data cables are seperated as far as possible from the power cables.
    however i think you will find that this is down to the head reaching end of life. i have seen it a few times on older generation Roland printers.
    hope this helps.
  • Tomas Vidziunas
    1 October 2008 at 18:30
    Thanks for reply Mark,
    do you know if heads are expensive, is it difficult to change one?
    It is an old printer and it was rarely used before and I thing that might be why all those printing problems started.
