Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters why is my graphtec plotter not cutting smooth ovals?
  • why is my graphtec plotter not cutting smooth ovals?
    Posted by John Wilson on 29 March 2006 at 17:55
    I have a graphtec 3000-60, when I’m cutting ovals it’s not cutting straight lines…. if that makes sense.
    It looks like a wavy line, is this normal?
    From a foot away it looks oval but very close up it’s not 😕
    Colin Hibbitt replied 19 years, 4 months ago 10 Members · 17 Replies
  • 17 Replies
    29 March 2006 at 18:06
    had this problem with other peoples eps files i redrew the oval within my sofwear or the blade is not free in its holder or vinyl saging between the rollers
  • John Wilson
    29 March 2006 at 19:05
    I’m sure the .eps is fine…. Andrew done it :lol1:
    I’ll check the rest in the morning
  • Kevin Flowers
    29 March 2006 at 22:04
    what software are you using some have adjustments for curve cutting, only got design version on the laptop so can’t check the correct terminology but hopefully you get the meaning. Also some cutters have a similar system, in the firmware adjustable via the control panel on the cutter.
  • John Wilson
    30 March 2006 at 08:37
    This isn’t fair, I’ve got a job this morning and I need to cut it asap but it’s just not looking right 🙁
  • Neil Roberts – Graphtec
    30 March 2006 at 08:56
    Hi John,
    I could do with a few more details to pin point the problem here. If you’re in a rush maybe best if you gave us a call.
    Neil
  • Misko
    1 April 2006 at 22:29
    If the oval has been imported, It may have buch of un-necessary nodes on it. If that is the case just clean it up. You need only 4 nodes to define any oval.
  • Misko
    1 April 2006 at 22:33
    If it is a file problem, and you have hard time fixing it, just e-mail it to me and I will take care of it for you.
  • John Wilson
    1 April 2006 at 22:40
    Cheers for the offer Misko, but it’s not a file problem…. I took it to my mate to cut and it was fine. I told him that it wasn’t cutting right on mine and he told me he had the same problem ages ago and it was down to plotter settings.
    It’s not cutting in a straight line when cutting the oval, i’ll post pics on monday with what I mean
  • Frank Droog
    2 April 2006 at 13:39
    Can the program you are using plot to a File?
    If it can, plot to a file called c:\test.plt
    Make sure it has a ".PLT" extension.
    Im sure the program you are using can import HPGL PLT files.
    Import it and see if its as wobbely on screen.
    If its fine on screen, its something up more than likely on the plotter.
    frank at cadlink
  • jeffus – Graphtec
    3 April 2006 at 13:38
    Hi John,
    Just a few questions get your pen ready, 🙂
    What software are you using?
    Are all other shapes/ text ok?
    Is there any play in the head assembly?
    Is the blade holder in good condition no play in the blade?
    Jeff
  • John Wilson
    15 August 2006 at 19:06
    I finally found the problem, seems that there was play in the head after all…. opened it so I could tweek the screws to tighten it and one of the screw buffer things is cracked 😮
    Guess I’ll need to phone in the morning and see what happens now 🙄
    16 August 2006 at 07:44
    quote John Wilson:
    oh yeah, I was going to suggest that 😕
  • John Wilson
    16 August 2006 at 08:52
    quote Neil Roberts – Graphtec:
    Hi John,
    Neil
    What’s the best number to call?
  • John Wilson
    22 August 2006 at 19:06
    Graphtec was out today and fixed the problem and everything is back to normal now 😀
    Cheers Graphtec….. hip hip hooray :lol1: :lol1:
    22 August 2006 at 19:11
    must say when we have had a problem with our graphtec the guy’s have alway’s been top notch 😀
  • John Wilson
    22 August 2006 at 19:12
    quote Lynn:
    Yeah I know, wish I phoned them when I first had the problem rather than wait but it’s done now 😎
  • Colin Hibbitt
    22 August 2006 at 20:51
    we have contract with graphtec – fc-1300 model – recommended them anytime – not many problems mainly bearings – its 7 yrs old and still cutting fine – occassionly when cutting text is not cutting freely but jaggedly this is because of the small strip of tape that the blade goes up and down gets worn and follows the grove not ctting properly – 25 note for new strip
