Home Forums Printing Discussions Uniform Printers why is my cadet not cutting in print and cut mode please?
  • why is my cadet not cutting in print and cut mode please?
    Posted by John Austin on 5 August 2008 at 20:20
    Can anyone help Cadet 760 running ecosolmax, colourip and illustrator cs2, prints fine but will not cut the contour line. Ive checked all the procedures but might be missing something.? It does test cut although it does a strange slight cut about 5mm just outside the test cut circle.?
    In illustrator i have Saved the cut line as contour-cutt and spot colour, stroke 0.25, mitre 1.
    In colorip checked process cutting paths and enable cutting.
    Also how do you nest horizontally in colorip. ?
    Im trying to set up a label workflow. Any help would be appreciated.
    Chris Wool replied 17 years, 5 months ago 4 Members · 11 Replies
  • 11 Replies
    5 August 2008 at 20:52
    quote :
    are you sure it should be CutPath for colourrip ?
  • Frank Horner
    5 August 2008 at 20:55
    Which rip are you using?
    Frank
  • John Austin
    5 August 2008 at 21:25
    Chris
    Sorry my mistake in the original post, ye i had saved it as Cutpath and not contour cut as mentioned above.
    Im sure ive done everything it says on the user guides. Still no joy.
    Thanks for reply
  • John Austin
    5 August 2008 at 21:26
    Frank
    Roland colour rip
    Thanks for reply
    5 August 2008 at 21:40
    check again it has to be CutPath
  • Adrian Yeo
    6 August 2008 at 06:42
    Defo CutPath, also thought it had to be ‘hairline’ or is that for Corel only? 😕
    6 August 2008 at 08:27
    Adrian as far as colourrip is concerned its the path name it reads not the width. a thicker line has its uses but generally keep it a hairline.
  • John Austin
    6 August 2008 at 10:41
    Hi Chris
    rechecked as you advised
    Problem solved. I had saved as cutpath but without the capitals.
    can you recommend good label materials / supplier ?
    Many Thanks
    John 😀
    6 August 2008 at 13:45
    quote :
    do you mean cheep vinyl ?
  • John Austin
    6 August 2008 at 16:51
    Hi Chris
    I really dont know what type are used for labels im already trying the cheapest Orafol opaque white and clear with good results, what about metalics ?.
    John :
    6 August 2008 at 19:51
    boils down to different types for different jobs and customer requirements, like do they want to write on them, chemical resistance, durability, and so on.
