Home Forums Printing Discussions Printer Ink why is it when printing black flags the ink looks grey?
  • why is it when printing black flags the ink looks grey?
    Posted by Richard Daniel on 4 July 2007 at 10:35
    Hi All
    I was Wondering if i could have some advice,
    We have done some flags for a client in black, when our JV3 finished printing them they looked a very light grey,
    we took a chance and put them up, The client has been in touch asking for them to replaced,
    He says they look like a pair of tights 🙄
    Basically i also think the flag material was too fine as well
    Does anyone know of a thicker material (i used Hexis for the last batch) and also howto get the prints darker, i have always known that you cannot print the perfect black flag, but we had soem printed before we got the JV3 and they are alot darker then waht ours come up with..
    Any advice would be appreciated advice
    Many Thanks
    Richard
    Nick Dowell replied 18 years, 1 month ago 7 Members · 10 Replies
  • 10 Replies
  • Mark Elvidge
    4 July 2007 at 15:43
    for the media try brook international of yorkshire.
    they have all kinds of flag and textile media.
    as for a darker black……try using an overprint feature from the rip, which will take twice as long to print but will double the amount of ink that goes down.
    or you could create the black as a true 4 colour black with 100% of everything to try and get more density and possibly add an overprint to this also.
    what rip do you use?
  • Richard Daniel
    4 July 2007 at 15:50
    Mark
    Many Thanks for getting back to me.
    Im using Shiraz, ive only had the printer and software a couple of months,
    This overrint sounds like it could be worth a shot, any idea of how to do it on shiraz?
    Thanks Again
  • Mark Elvidge
    4 July 2007 at 16:13
    if you are using v6 then it is under the print tab in the design screen.
    version 5.61 i can remember of the top of my head i will check.
    enable the tick box for black or cmyk.
  • Richard Daniel
    4 July 2007 at 19:09
    Many thanks mate
    I will give this a try and let you know how i get on
    Thanks again
  • Richard Daniel
    17 July 2007 at 14:53
    Anyone else know a good supplier of flag material?
    Brook have some quality products but only do a 50m roll,
    i was only look for say 20?
    If anyone can suggest a company that would be great
    Many thanks
    Richard
  • Carlo Morelli
    13 August 2007 at 23:25
    Hi, I had a similar problem and it wasn’t the material, it was the way the file was created. If you have a solid black, means 100% black / 0 cyan / 0 Magenta / 0 Yellow, your black will looks weak.
    •If your file is in RGB it is even worse because the "black" has to be artificially generated by the decomposition of RGB gamma.
    • If your file is saved as a PDF will not understand the conversion at all.
    My advise is to open your art file in Photoshop, make it a CMYK (keep it in background flat, not layers) and go to Image + Adjustments + Channel Mixer and select Output Channel black. Then under Source Channels increase de amount of Cyan, Magenta and Yellow in this order +40%, +40%, +50%, black should still +100%. It won’t affect any other part of the artwork, just the black channel. Your black will looks real black. Please keep a separated copy of your original file, just in case.
    Saved as a tiff file. If you want a smaller file save it as a Tiff with LZW compression.
    I hope it will help.
    Carlo Morelli
  • DigitalBlueprint
    25 October 2007 at 13:15
    Thank you Carlo,
    Good observation!
    I noticed that blacks turned gray in pdf compressions.
    This advice of yours not only helps for printing but also when sending proofs. This is great! I’m new to this and so this is a learning experience.
    Thanks a lot!
  • Dennis Van Der Lingen
    24 November 2007 at 13:22
    there a two ways to print flags:
    screen printing (100% printquality) them or using dye sublimation.(90 to 95% printquality)
    with these two methods you get a good flag that will stand up to the weather for about 3 to 6 months.
    using mild or eco solvent creates flags that weak and pale.
    I think it is wrong for the suppliers to present the material as being compatible with your solvent printer. because they are not.
    saying it any other way is like telling a lie. be carefull with this because if you’re not you’ll be forced to replace every flag you’ll make
  • Warren Beard
    24 November 2007 at 14:43
    I can confirm Carlo’s way is the best way to print a strong black, DO NOT make all 4 colours 100%, do as Carlo suggested.
  • Nick Dowell
    26 November 2007 at 13:25
    I have to agree with Dennis. Although you can print polyester on Eco solvent printers they look no where near as good as Screen or die-sub printed flags.
    mod-edit 2 see board rules for suppliers. :police3:
    Nick
