Home Forums Sign Making Discussions Vinyl why is banner vinyl peeling off prematurely?
  • why is banner vinyl peeling off prematurely?
    Posted by Ewan Chrystal on 27 May 2013 at 23:42
    Made a banner 3 weeks ago using macsoft white vinyl. It was fitted at room temperature and has only been used indoors since. The customer called today to say the vinyl was coming off the banner. The vinyl is lifting around every edge.
    What could be causing this? I will obviously be re doing it for the customer but ive not had this problem before so i’m a bit wary about using the same vinyl.
    Ewan
    Adrian Hewson replied 12 years, 1 month ago 17 Members · 23 Replies
  • 23 Replies
    28 May 2013 at 00:19
    How did you clean the banner before applying the banner vinyl Ewan & did you post heat it at all?
  • Ewan Chrystal
    28 May 2013 at 06:47
    Banner was cleaned with turps and no heat was applied
  • Derek Heron
    28 May 2013 at 07:19
    personally i wouldnt clean with turps
    i have isoprop alcohol but this sometimes leaves a residue
    best i have used is the avery cleaner use it on all surfaces now with excelent results
    also would post heat the text etc on banners on banners
    derek
  • NeilRoss
    28 May 2013 at 07:58
    As Derek says, I wouldn’t use turps either. Turps will leave a petroleum film on the surface and effectively create a barrier between the vinyl adhesive and the banner material. I’ve used all sorts of cleaning fluids but always gone back to simply washing them with warm water and Jif (renamed nowadays I think) sponge rinsed off and dried and have never had any problems at all, even on long term jobs. Post heating as well.
  • David Rogers
    28 May 2013 at 07:59
    Turps is pretty oily so leaves a residue.
    Isopropyl or even meths cleans & degreases pretty well.
    Heating on shouldn’t be necessary but does ensure a superior grab.
    I think the turps was your downfall on this occasion.
  • Ewan Chrystal
    28 May 2013 at 08:50
    Thanks all, time to change the cleaning fluid. Can’t remembe where or who but I was told that turps was the best thing to use.
    Ah well, still learning
    29 May 2013 at 07:48
    I would never use turps /white spirit for reasons stated above. I use either glue and tar remover (make sure it had dried thoroughly ) or meths.
    Alan D
  • Richard Urquhart
    1 June 2013 at 21:32
    I would never use turps, use rapid prep or Avery surface cleaner and you won’t have any problems.
  • Ewan Chrystal
    1 June 2013 at 23:57
    Have now changed to meths
  • Duncan Wilkie
    2 June 2013 at 00:24
    It could be the vinyl itself, but I agree, never use an oil solvent like turps to clean the surface.
    Plasticizer Migration can cause vinyl graphics to peel off too. Not all vinyl fabrics are suitable for sign work. Plasticizers are used to keep the material soft and flexible. If there is an excess of it in the material, it may migrate to the surface and slough off along with the lettering. Here’s a detailed description of the condition.
    http://www.flex-europa.com/products_plasticizer.htm
  • Neil Davey
    2 June 2013 at 09:55
    As above I never use turps or white spirit for cleaning (other than when I spell something wrong while painting a sign!!)
    I used meths for years but even that leaves a slight residue so now we use Avery or Image Perfect surface cleaner.
    Meths doesn’t taste good either 😕
  • Simon Worrall
    2 June 2013 at 10:11
    We always use, in the following order, for every job:
    1 Water with detergent
    2 Prepsol, (Also known as Prepwash, Autoclean, Solwash)
    3 Isopropyl alcohol.
    We have never yet had a failure due to grease or dirt.
    All the above are available cheaply in bulk.
    Simon.
    2 June 2013 at 13:26
    I agree with the others, I think your downfall was the turps!
    Completely scrap using that for anything connected to your vinyl work mate.
    Isopropyl alcohol or Industrial Meths is what i prefer to use.
    dont buy from the likes of B&Q though, buy it from a Janitorial / Cleaning Chemicals type supplier. You will buy it in 25litre drums which will last you months and only cost about £30ish
    Buying from local stories will cost you about £10 for a small hand size bottle. 😕
    Industrial Meths is Clear, domestic is purple. dont buy the domestic stuff, the purple in it can dye certain surfaces, including resprayed vehicles. i have that T-shirt from many moons ago. 😉
    Be careful buying either ISO or Meths thats clear, make sure you have a sealed container as you maybe buying watered down bottles, which is not uncommon. you can tell if it doesnt remove the likes of pen ink on first swipe, or if the fluid beads on the surface rather than evaporates very fast.
    There are ways the vinyl can fail simply by the way the customer treats the banner. if the banner is folded rather than "rolled". this can create dog-earing of the vinyl, creases and so on.
    also, you cannot roll it tight. loose or around an old card vinyl core tube.
    You MUST roll the banner with the vinyl facing out, not inwards as again this can cause the vinyl to come off.
    apply with a nylon squeegee rather than felt.
    heat promotes adhesion also, but dont overheat one area or you can create gloss patches on the banner.
    if you banner is stiched, dont cross the stitching with vinyl. to be honest if you do your too close to the edge with vinyl anyway. :lol1:
  • Ewan Chrystal
    2 June 2013 at 22:06
    Found a place that sells it and there was this message……..
    IMPORTANT
    You will need to register your interest in this product with HM Revenue and Customs before we can supply you. Please call them on 0845 010 9000 and they will send you a registration letter. It does not take long and HM Customs and Excise are normally really helpful. They normally refer to this product as ‘IDA’ or ‘Industrial Denatured Alcohol’.
    3 June 2013 at 09:05
    I use to buy IPA from Alpha Chemicals Ewan, I say use to because I haven’t bought any for a couple of years now. 25 ltrs lasts a long time when you only work part time lol.
    Think they are based in Denny, 01324 824181
    Don’t know if those details are up to date but you should find them with a search.
  • Martin Cole
    3 June 2013 at 09:22
    http://www.shinyhardware.co.uk/prods/sh … p?cid=3563
    good for Isopropanol
  • Kevin Busby
    4 June 2013 at 16:10
    quote Martin Cole:
    Nice one thanks, Just ordered very reasonable.
    4 June 2013 at 16:48
    yep +1 for the shiny people
  • Chris Windebank
    4 June 2013 at 18:23
    shiny for me too, great price
  • Kevin Busby
    4 June 2013 at 19:00
    Next time you order Martin you should ask for commission lol.
  • Martin Cole
    5 June 2013 at 11:57
    quote Kevin Busby:
    A guy who helped me wrap some vans the other week told me about them.
    A lot of ‘Shiny Happy People’….. (-music)
  • Gary Birch
    2 October 2013 at 11:49
    quote Martin Cole:
    quote Kevin Busby:
    + 1 more here 😉 Cheers Martin
  • Adrian Hewson
    3 October 2013 at 03:46
    http://www.bonnymans.co.uk/products/pro … ticleID=-1
    WE buy it is 205 litre drums from here about £175 I seem to remember
