Home Forums Vinyl Cutter Discussions Roland Cutters why have the heads on vp300 stopped working?
  • why have the heads on vp300 stopped working?
    Posted by Martin Armitage on 19 September 2008 at 14:20
    Hi, I was printing a banner and half way through one side of the magenta head stopped working, so I gave it a clean started to print, within an inch of starting it happened again – but this time one side of the magenta and one side of the yellow had stopped working completely no ink at all. The right hand side of both was fine, I have given it a clean and so far so good. Is this a sign of something about to happen to my machine? Or is it normal and I am worrying too much.
    Mart.
    Martin Armitage replied 17 years ago 6 Members · 7 Replies
  • 7 Replies
    19 September 2008 at 14:38
    are you sure it has not run out of ink, similar happened to me and the empty tag on the cart had not triggered the machine.
    later found out there was a few carts like this
  • Martin Armitage
    19 September 2008 at 15:03
    Hi Chris,
    Its a new magenta cart, and the yellow is showing half full, i have just printed an 1800 mm banner with no problem.
    Mart.
  • Chris Rundle
    14 December 2008 at 13:04
    Hi don’t know if this will be any help did you shake the cartridge before inserting it into the machine? because with my versacamm i always have to shake the cartridges before inserting them!
    if not any help you will have to get an engineer out to sort it.
    hope this is some help!
    14 December 2008 at 14:47
    hi. i strongly suggest NO shaking of carts… this creates bubbles, although air cannot get into a cart but there is really no need.
  • Nick Minall
    14 December 2008 at 16:35
    quote Dave Rowland:
    Roland say to gently shake them before fitting.
  • Richard Urquhart
    14 December 2008 at 16:44
    Ah Roland !!
  • Martin Armitage
    14 December 2008 at 17:09
    I started the versacamm next day, and it worked fine and has so ever since. Sometimes just turning it off and back on again can clear faults. Luckily I had checked it, as I had just organised a call out from an engineer.
    Mart
