Home Forums Sign Making Discussions Graphic Design Help Why does this look different in flexi?
  • Why does this look different in flexi?
    Posted by Ewan Chrystal on 20 November 2014 at 08:51
    The first image is an AI file and the second is the same file opened in Flexisign. What would cause the block of colour where the shadow should be?
    Kevin Flowers replied 11 years, 1 month ago 5 Members · 8 Replies
  • 8 Replies
    20 November 2014 at 09:24
    I suspect the image is vector drawn whereas the "soft shadow" is a rendered (rasterised) image. The solid look to the soft shadow in flexi is a result of how it handles rendered images within the file. If it’s a version of Flexi that is for cut vinyl only then it probably can’t handle rendered images properly since soft shadow effects can only be achieved by printing them.
  • Ewan Chrystal
    20 November 2014 at 09:39
    It was opened in flexi pro and unfortunately printed the solid shadow
    20 November 2014 at 09:48
    Can you by-pass flexi and print directly from the ai file?
  • Ewan Chrystal
    20 November 2014 at 10:00
    Probably, i’m just trying to establish if its a problem at my end or whether the problem comes from whoever designed it
  • David McDonald
    20 November 2014 at 13:15
    Hi Ewan
    This isn’t uncommon with Flexisign – soft shadows become solid, gradients become 100’s of small vectors etc. etc.
    It’s not just the ‘cut’ versions – does it on them all.
    As Phil says print from Illustrator, or export as an EPS into your RIP – haven’t seen a RIP that takes native AI files?
    Macky
  • Ewan Chrystal
    20 November 2014 at 14:04
    Ive done a normal print straight from AI and it was perfect, so it looks like a flexi issue. Thanks for the replies. will need to remember that for the future
  • Jon Marshall
    20 November 2014 at 15:27
    Flexi doesn’t handle Illustrator files all that well, especially with all the constant updates to Illustrator.
  • Kevin Flowers
    20 November 2014 at 16:51
    Ewan
    subject to which version of Flexi you are using it does support rendered transparent shadows but still struggles with AI files i use to just recreate the shadow directly in Flexi
