Home Forums Software Discussions Corel Software why does the gradient lines not look right when converted?
  • why does the gradient lines not look right when converted?
    Posted by Dan Saunders on 23 May 2008 at 12:08
    Ello……. Im not sure if this topic has been touched on before and if so sorry for going through it again. I have been given some artwork from a customer to print.
    The print has a fading skyline which on screen ( corel 13 ) looks fine but when i converted to EPS for printing the Fading has gradient lines instead of the nice Fading. I also have the same problem when doing fills in my own artowrk.
    Any surgestions ?
    Mike Fear replied 17 years, 7 months ago 5 Members · 5 Replies
  • Chris-Hooper
    23 May 2008 at 12:18
    try up the steps in the fill or convert the fill to a bitmap or j’peg b4 printing i’ve had this problem before with corel
    23 May 2008 at 12:53
    yep convert to bitmap gets around it.. dont worry too much about high dpi values..
    basically design gradients is a bit of an art, a lot of people don’t know how to draw gradients so they step on print.
    23 May 2008 at 14:11
    A useful tip – once you have converted to a bmp or jpg – if the steps are still visible add some "noise" to the file using a distortion filter such as available in corel photopaint or photoshop – this will eliminate the banding.
    23 May 2008 at 14:22
    Yes convert to a bitmap and as Phill says add some noise – I use gaussian blur.
    Alan D
  • Mike Fear
    24 May 2008 at 07:45
    The method I use, is when making the gradient set the number of steps to 1000, this gives a nice smooth colour fade. When you export as an EPS make sure you keep the resolution high and you should have no problems printing.
