Home › Forums › Printing Discussions › Mimaki Printers › why does rockhopper keep printing green tint on all imagery?
Posted by Adam Hilson on 12 January 2008 at 23:36I’m having an on/off (more on) problem with my Rockhopper II.
The printer seems to (without any changes made to profiles or settings) print a green tint on all imagery.
The first time this happened, I tried some different profiles within Onyx, which seemed to work after a few attempts.This lasted a couple of weeks until it happened again, without me changing any settings to either the printer or any software the green tint came back.
The last few times it’s happened, I’ve had to trial and error with colour correction in Onyx to get the green tint less visible.
Surely this shouldn’t happen on it’s own? I can only assume its a software/communication problem … maybe?
I’m currently running Onyx 6.5 and using Bulk Ink System (by Inktech Inks)
Any help will be much appreciated
Adam H
Adam Hilson replied 17 years, 11 months ago 3 Members · 8 Replies -
Have you tried printing it in different colour modes? Have a look at the original file to see if its CYMK or RGB, sometimes this can be the case.
It happened to me before where i was printing an image for a deli and some images looked as they should and there was just one image printed on the same material etc as the others but had a green tinge to it (been food not very appetising!).
After much hair pulling i went back to the file in photoshop and discovered i had it in RGB mode instead of CYMK.
I then changed it in Photoshop via <Image> and all was good.
Hope this is of some help.. if only for the process of elimination. -
Hi Lorraine,
Thanks for the reply, I’ll give that a go. Does the image have to be saved as a PSD for the CMYK to register? Or will JPEG do?
I think I have got around the current image by changing the media type in Onyx, it looks a lot less green but there’s still a sepia look to the printed image.
Hi Adam, a Jpeg should be fine once its in CYMK mode.
The way i would check is i would open the jpeg in photoshop go to the menu bar and you will see the "image" menu, from that image menu you will see "mode" just click on that and you will see a tick beside whatever mode the file is in.
If its in RGB just tick it to CYMK and save.Also in the RIP check that in your print settings its on CYMK mode.
Best of luck with it 🙂
Hi Lorraine,
I thought the change in media type had fixed the tint, but I dont think it has.
I tried an image converting to CMYK in Photoshop, but its still doing it.The tint problem is annoying itself, but the way it keeps happening after fixing it is the main grief I’m getting.
Thanks,
Adam H -
Just an update:
I’ve just carried out a test print. I made 4 bars in Photoshop, each bar being either K, C, Y or M. The bar would be a gradual fade from 100% to 0% of each colour.
It all started out fine, but as the colours started to get closer to 0%, there was a noticable amount of green tint appearing (the most noticable colour was K).I carried out a similar test earlier with a JPEG file (saved as CMYK in Photoshop) and the C line had a tint of green to it … the latest test was saved as an EPS file and the C line was almost completely C 🙂
Edit
The green tint starts to appear when each colour gets around 50%, any lower than this and the green becomes more and more visible.
On the K line, it’s very bizzare because why is the printer printing a green tint when the line should be Black to White (therefore grey in the middle) … but in this instance, its Black – Dark Grey – Light Green – Small amount of White -
quote :On the K line, it’s very bizzare because why is the printer printing a green tint when the line should be Black to White (therefore grey in the middle) … but in this instance, its Black – Dark Grey – Light Green – Small amount of White
on some rips the K is not used until the shade of black is above 50%, the Gray is made up of all colours if out of balance it has a tint.
in PS as you put the cursor over a grey area of the image then the RGB values should be equal.
dont understand why it should come and go. apart from you having a profile switched on sometimes as you save.chris
quote Adam H:Just an update:
Edit
On the K line, it’s very bizzare because why is the printer printing a green tint when the line should be Black to White (therefore grey in the middle) … but in this instance, its Black – Dark Grey – Light Green – Small amount of WhiteHi Adam, is it only with printing tints / gradients you are having the problem?
Can i see the file or if its too big just a slice of it? -
Chris Wool:
I tried a profile which has worked no problem before, and this did make the tint less obvious, but the tint is still there.
As the tint is green, am I right in thinking its the C and Y colours that are out of balance ?The colours look perfect in PS, its only on the print itself when the tint appears.
Interesting point though, I would of thought the printer would use K for the entire K line?
Lorraine Burke:
The tint appears on all prints. An image I tried last night was most noticealbe as the image was supposed to be Black & White, but where the Black became lighter and where White should of been present, there was a definate colour tint.
I shall try to get some pictures up to show whats happening.
