Home Forums Sign Making Discussions Vinyl why does my vinyl letters peel after printing?
  • why does my vinyl letters peel after printing?
    Posted by EddieMohan on 24 October 2007 at 20:58
    hi bit of a problem
    i have some printed cut letters that have started to peel of a lorry cab. so i reprinted/cut the letters. the next morning they had started to peel of the backing paper. so i did it again. this time i put the application paper on straight a way, it worked but only just as it was starting to peel/curl already. haven’t contacted my supplier yet.
    has anyone any ideas?
    Chris Wool replied 18 years, 1 month ago 5 Members · 6 Replies
    24 October 2007 at 21:09
    I’m guessing you printed right to the edge of the vinyl, then contour cut?
    it is advised that you leave a small border on text/graphics like this or leave the prints to dry/out gas for a while before contour cutting.
    your machine will have a delay setting to allow for this sort of thing. i.e. prints the graphics and pauses for as long as possible setting, then proceeds to contour cut. to be honest though, thats more for small stickers etc…
    basically the solvent attacks the vinyl until it out-gasses. due to the cutting, the vinyl as no option but to curl. if you are fitting these to a vehicle you should be leaving them a minimum of 24hrs before application.
  • EddieMohan
    24 October 2007 at 21:25
    thanks, I’ll have to look into the delay thing
  • John Childs
    24 October 2007 at 23:08
    This is exactly the reason why I see no advantage in a print-and-cut machine.
    My method would be to print, take the vinyl out so that I can get on with other printing jobs, then at least twenty four hours later put the print back in and cut it.
    My point is – why should I have to delay the urgent job I might be printing tomorrow when it is just as easy to do the cutting on a separate machine?
  • Andy Gorman
    24 October 2007 at 23:44
    Depends what you’re printing I s’pose. If the print stops before the cut line then it’s ideal. I know what you mean John, production-wise it could be a pain in the arse but you’ve got to remove the print to laminate anyway.
    Coincidently, I had a call yesterday from a customer experiencing the same issue – curling of the edges. Bah!
  • John Childs
    24 October 2007 at 23:55
    quote Andy Gorman:
    Exactly. 😀
    I’ve never had curling before, but I think I might have one now. Had a call from a customer and from his description it sounds like it.
    The thing is, I know that the item he was talking about was done in a hurry. Another lesson learned the expensive way. 🙁
    25 October 2007 at 00:13
    some vinyls are worse for it than others my experience is 3m 40 series is the least shrinkage if cut threw ink.
    lamination then cutting generally cures it.
    i do have one customer that suffers from curling prints but he understands its his staff pressure washing the truck to close. he cant get the lads to understand sponge the dirt of then rinse.
