Home Forums Software Discussions Signlab Software why does my copy of signlab not have the undo facility?
  • why does my copy of signlab not have the undo facility?
    Posted by francopas on 14 April 2005 at 09:18
    we are running signlab 5 on windows 2000 and we have just installed a new computer which is runnung xp home..i have installed signlab 5 but there are no undo available..
    we had the same problem once in windows 2000 and the problem was sorted out by changing the virtual memory settings but i am having no joy with changing the settings on xp….
    could it be that signlab 5 is too an old a version to run on xp??????
    trevb replied 20 years, 8 months ago 4 Members · 4 Replies
  • Rod Gray
    14 April 2005 at 10:30
    If i remember correctly, the problem was something to do with having more than 512mb of system RAM.
    The way you described your solution is correct. If that doesn`t work and assuming you have 1gb of RAM, try removing one of the 512mb chips and trying that?.
  • francopas
    14 April 2005 at 11:27
    i want to keep the gig of ram because of other software we are using but on our 2000 system i had a gig of ram and that worked fine….
  • J. Hulme
    14 April 2005 at 16:41
    Is this no undo available at all or no undo available on previously saved jobs? if the latter, you’ll need to copy the undo files to your new system too, when you save a file it will create another file along side it as an undo.
  • trevb
    14 April 2005 at 18:22
    I think this problem has to do with the fact that physical RAM + Virtual Memory exceeds 2 GB. The only workaround without removing RAM from the system is to reduce Windows virtual memory to under 1 GB so that the sum of the two does not exceed 2 GB RAM.
    Newer versions of Signlab do not exhibit this problem.
    Cheers!
    Trev B
    CADlink
