Home › Forums › Software Discussions › Adobe Software › Why does my 100% K change?
Posted by Warren Beard on 5 August 2010 at 15:32Hi All
I keep getting this issue and can’t resolve and it is a problem, I save something using 100% K and it converts to CMYK black which uses about 300% ink and floods on the vinyl so it HAS to be changed or causes major issues but every time I change it I find it has changed back when I re-open it.
Using Illustrator CS4
Warren
David Rowland replied 15 years, 4 months ago 5 Members · 11 Replies -
Your not saving it as RGB are you Warren, that would change the values of cmyk.
No, and if it is RGB I change it to CMYK and it still does the same.
its a replacement black thing… confirm that 100% cyan is 100% cyan?
Have you told it not to colour manage that document
Got to go out now hope you sort it warren.
Try edit – colour settings – you can turn off colour management here or better would be assign a profile to that document – turn off colour management in that document.Steve
it’s happening on more than one document though, it did it once before and don’t know how I solved it and now it’s started again 😕
I’ll keep trying but thanks anyway.
had similar with a customers file flooding black as i could not alter it i set the rip max ink to 120% as opposed to my normal 240%
warren did you find a pm from me.
One company I work for sends art work ready files, their black come out as Warren has said and floods the vinyl, I just change the colour in signlab and print, so for me its not a problem, however it shows this happens with other peoples files that get sent to me. Rich
Make sure you’ve got preserve numbers selected in colour management for cmyk.
if ur getting printer-pooling of black, raise your heaters!!
