Home Forums Software Discussions Corel Software why does a gradient fill break apart when converted to eps?
  • why does a gradient fill break apart when converted to eps?
    Posted by Dan Saunders on 17 November 2008 at 16:06
    I was wondering if anyone could help me PLEASE !!
    I have created some logo in corel and have used the fill tool to fade from red to dark gray.
    All looks fine on screen but when i convert to EPS for printing the fill breaks apart and each gradient segment can now move…..what on earth is going on ? never had this problem before and i got to get the job done for thursday.
    Maybe the Export to EPS settings are wrong ?
    mod-edit please post
    in the correct forum
    this has now been moved
    Dan Saunders replied 17 years, 1 month ago 5 Members · 8 Replies
  • 8 Replies
  • Karl Williams
    17 November 2008 at 16:08
    Export as a tiff file.
  • Dan Saunders
    17 November 2008 at 16:16
    in the EPS export settings it says its a Tiff 8bit 300dpi i have the header box ticked and also the transparent background ticked to
    17 November 2008 at 16:28
    quote Dan Saunders:
    not the same as karl is suggesting
    export as a HQ JPEG or Tiff and rip that
    or import the bit map after converting and apply a cut line then export as a eps.
    a eps breaks down a fade in to steps according to the fountain fill steps command
  • Dan Saunders
    17 November 2008 at 16:32
    ok thanks i shall try that….im sorry still teaching my self…why cant things be easy 🙂
    Dan
  • Dan Saunders
    17 November 2008 at 16:59
    I have just did as suggested. Converted logo into hi rez jpeg and then added cutmark Then converted into EPS now when i send it to coloRIP but when it finally loads theres nowt on screen…..Am i going mad ? 😮
  • Ian Muir
    17 November 2008 at 17:15
    yes
    Eco :lol1:
    18 November 2008 at 08:19
    Fades being converted to small bits is an eps limitation as I understand it. You can create a square/oblong with your fill, convert to jpg and then power clip that into your cut shape, export as eps. Also try exporting as pdf as this doesn’t seem to break the fill apart.
    Alan D
  • Dan Saunders
    18 November 2008 at 09:51
    Thanks…the PDF way worked thank goodness.
    Im going to have to join as a full member sometime soon.
    Thanks again.
