Home Forums Vinyl Cutter Discussions Summa Cutters why do i get cannot ‘detect baud rate’ error with summa?
  • why do i get cannot ‘detect baud rate’ error with summa?
    Posted by Pazz on 9 February 2008 at 20:37
    Hi guys, this is a new area of work for me. I have just purchased a d1220 cutter for £50 (cheap I think), have downloaded s/ware from summa website and have had no luck getting work to the cutter. The summa will initialize it will do a test cut (right arrow when powering on it will also plot settings on board cutter to a sheet of paper) so things cant be too bad.
    When I load the cutter tools on my PC everything looks ok until I try to access any settings on the cutter, it comes back with "cannot detect baud rate" in a box on the screen.
    please any ideas gentlemen.
    ps with an osccilloscope on pin 3 of the circuit board in the end of the cutter there is data coming from my pc!!! (while it is trying to auto-detect baud rate)
    Karl Williams replied 17 years, 11 months ago 5 Members · 7 Replies
  • 7 Replies
    9 February 2008 at 20:44
    if serial connection it must be the correct cable.
    pin 2 -3 crossed over if i remember.
    if you connect via lpt port the plotter can not be polled as to its set up width.
  • Karl Williams
    9 February 2008 at 22:09
    Check your settings in winplot. The baud rate settings should be 9600.
    You’d better introduce yourself before someone chews your leg off. 😉
    9 February 2008 at 22:11
    quote Karl Williams:
    :lol1: :lol1: you have a lovely way with words karl 😉
  • Karl Williams
    9 February 2008 at 22:14
    Just thought I’d warn him before Stormin’ Norman gets to him! 😉 😀
  • Mike Grant
    10 February 2008 at 19:01
    I think it will only give you the baud rate info AFTER you have loaded the machine with media.
  • Pazz
    10 February 2008 at 21:01
    Thank you very much Chris Wool, So obvious, tried a "null modem cable " and BINGO it all spings to life. Completely forgot that 2&3 pins needed to be swapped !!!(should have known that from my years as a computer engineer)
    I have never used a vinyl cutter before and I am amazed at how fast and accurate they are.
    Can anybody recommend a budget piece of cutting s/ware (am currently using a trial version of signblazer!)
    Again thank you very much for your help
    Pazz.
  • Karl Williams
    10 February 2008 at 21:05
    Hi Pazz.
    Glad you got it working mate. If you use coral 11 – 12 or X3 you can down load winplot from the Summa site for free. Works a treat.
