Home Forums Printing Discussions Sublimation Printing why am I getting a fuzzy print on my mugs?
  • why am I getting a fuzzy print on my mugs?
    Posted by Chris Wool on 28 July 2009 at 16:31
    ok
    printed some blue print to mugs and removed the paper very soon after coming out of the press, and the print looked nice and sharp.
    after they had cooled down the print has a sort of clouded edge going upwards.
    what i am thinking is the ink is still gassing from the heat of the mug. the last time i plunged a hot mug in to cold water it cracked. so any better ideas please.
    or should the water be warmed up a bit
    Emily replied 16 years, 4 months ago 5 Members · 6 Replies
  • Justin Mann
    28 July 2009 at 17:37
    I always dunk them in luke warm water after quickly removing the transfer paper. Obv. the water gets heated up very quickly if you do more than a few mugs so I tend to cool it back down a little.
    It certainly sounds like it’s the image creeping.
    Justin
  • mbroad
    28 July 2009 at 18:18
    I would agree. The dunking in luke warm water is to remove the immediate heat from the ceramic as it will retain quite a bit of heat for some time and the sublimation ink could migrate. If it is particularly cold you may get away without putting a mug in water or if the images don’t have well defined edges. Putting the mug in boiling water would even be cooler than the 180 degrees heat of the mug press – not recommended though :-). So warm water does the same job as cold water from the tap and would avoid the shock to the mug which could cause it to crack.
    28 July 2009 at 20:22
    thanks looks like i will try and some luke warm water.
    it was annoying as it looked so good until they had cooled by which time i had done 6. so try again tomorrow.
  • Mark Jahn
    28 July 2009 at 21:55
    Maybe try dropping the temp or baking time a fraction as an alternative Chris.
    29 July 2009 at 16:13
    perfect thank you all
  • Emily
    19 August 2009 at 15:12
    hi there, i know i’m not that experienced with mugs and sublimationbut i’d like to add,(it may help some) that we had a similar experience to this….you know what it was??
    we had the sublimation paper the wrong way round!!! :lol1:
