Home Forums Sign Making Discussions Vinyl White vinyl High-tack for OSB Sheathing Plywood?
  • White vinyl High-tack for OSB Sheathing Plywood?
    Posted by Patrick Donaghey on 3 December 2019 at 18:08
    Hi, folks, has anyone got vinyl that will stick onto painted OSB sheets for a site hoarding white vinyl just to cut any ideas?
    Tim de Beir replied 5 years, 11 months ago 4 Members · 4 Replies
    4 December 2019 at 07:44
    DPF8000 will stick to it like, you know what to a blanket, although you’ll still the texture through it.
    Perhaps something like Mactac’s WW300 will be better, from memory it’s a bit thicker and should hide the texture of the wood – plus it’s probably cheaper.
  • Iain Pearson
    4 December 2019 at 08:46
    Put a coat of PVA on first – most vinyl will stick to it then
  • Patrick Donaghey
    4 December 2019 at 12:40
    cheers it to look like a stencil anyway so the wood coming threw isnt a problem , thanks for the replies
  • Tim de Beir
    4 January 2020 at 15:41
    For wat it’s worth I use the Orajet High Tack 3105 or 3106, no pre-treat needed and sticks as hell, it is also printvinyl so 2 for 1!
