Home Forums Printing Discussions General Printing Topics White edge on edge
  • George Zerbino
    28 November 2008 at 14:06
    In Composer, go to the help menu and search for overprint, overlap, choke & spread.
    There are visual examples of what these functions do and how to use them, which is easier than explaining here.
    Regards,
  • George Zerbino
    28 November 2008 at 14:12
    Nearly forgot, this is under the assumption that you are using Omega to run the edge.
  • Shaun Harris
    29 November 2008 at 19:15
    Using Signlab.
  • Jason Davies
    29 November 2008 at 20:53
    Your trapping is out, probably because the foils are slightly different lengths, pressures are different etc so these will never line up, you will have to compensate for the gap using your software and overprinting.
    Good luck
