Home Forums Sign Making Discussions General Sign Topics which way to go about this?
  • which way to go about this?
    Posted by Damian Reeves on 29 May 2015 at 18:16
    Got a job that needs doing and wondering which is the best way to go about it.
    It’s a 2 colour graphic that needs to be pre layered as it is being sent out.
    It’s basically a blue shield with a white dog and some white text
    whole graphic is roughly 600mm x 350
    My initial feeling is to layer the white onto the blue as the blue is effectively the background.
    I do a fair bit of layering and using ref marks etc but I Have more or less done this when applying.
    since I am not applying it got me thinking if their is a better way to approach it.
    I’ve attached the pictures of the graphic
    the stripes will be done using etch vinyl which is air release so I’m not too fussed about that part.
    Options please
    Damian Reeves replied 10 years, 7 months ago 5 Members · 9 Replies
  • 9 Replies
    29 May 2015 at 20:16
    I would, cut the white with the blank space @ 600×350, app tape & trim to size,
    Peel off the backing paper so it’s adhesive side up on the bench/light box, align the frost, then align the blue, remove reg marks, and use the backing from the white to cover it all.
    When fitting you’ll likely get trapped air where it’s layered.
  • Damian Reeves
    29 May 2015 at 21:05
    quote David Hammond:
    That’s what I am trying to avoid too many air bubbles.
    I have spoken with the customer about this issue and told them bluntly what may or may not happen. but still want it pre layering
    Although your method is worth a thought, never thought of adhesive side up
    29 May 2015 at 21:24
    I think someone suggested to try air release vinyl on the bottom layer. Never tried it myself.
  • Damian Reeves
    29 May 2015 at 21:44
    I did see that mentioned somewhere but to be honest for what it is and it’s size doesn’t really warrent ordering it in
    as the rest of the order is straightforward it’s just this which there is only 1 so not really worth it
  • Shawn Bentley
    30 May 2015 at 19:45
    just my 2 penneth worth but id print and laminate it, its alot easier and better finish if you can.
    30 May 2015 at 20:06
    I agree, if printing it is an option, then i would go that route. I am guessing its not or you wouldn’t be doing it this way in the first instance?
    layering vinyl, then applying will give you micro-bubbles all around the perimeter of the second lather.
    Try thinking of the second layer as a little "step-up or step-down" for the squeegee.
    when we squeegee the squeegee is travelling at speed and will drop down the step missing the tiny area below it which causes the bubbles.
    Other areas where the second layer may have lets say a circle in it. this will create a complete pocket where the squeegee will not come into contact with the layer below it. again causing trapped air.
    Now "throw in" your customer is fitting it! and you have no chance of getting it right first time.
    to TRY reduce bubbles its best to use a felt squeegee because the felt edge can mould into areas of the "step" better than a nylon edged squeegee, which would just bump up/down the step.
    hope this made sense! 😕 :lol1:
  • Damian Reeves
    31 May 2015 at 00:31
    quote Robert Lambie:
    Try thinking of the second layer as a little “step-up or step-down” for the squeegee.
    Now “throw in” your customer is fitting it! and you have no chance of getting it right first time.
    to TRY reduce bubbles its best to use a felt squeegee because the felt edge can mould into areas of the “step” better than a nylon edged squeegee, which would just bump up/down the step.
    Your right printing isn’t an option
    I have told the customer that it really does need a printer and laminate job for best results.
    not quite sure why they won’t take the advice and slight extra cost for best result.
    I’ve given it a test run on a smaller scale usig. Some scrap material and sent the customer thks result via email so I am kind of hoping they. Eventually see sense.
    Even though I would not get much of a mark up on that particular logo I’d rather have them with it done properly.
    But I suppose it’s like most customers these days they always know best and penny pinch anywhere they can!
  • Kevin Flowers
    31 May 2015 at 20:03
    the price difference between 3 layers and print should be very minimal, are you charging too little for your 3 layer job
  • Damian Reeves
    31 May 2015 at 21:21
    quote Kevin Flowers:
    Cheers kev the overall job is in line with rates that’s not the issue
    although I think my local printers are charging too much for a trade service
    it’s something I have been meaning to look at for a while.
    Maybe get myself aquented to some of the reccomend on the board.
    I must admit though I am not totally blameless as I left it quite late
    Ultimately the customer opted for the cut vinyl layered which I have now done so it’s awaiting despatch.
    A slight oversight from the overall job as the rest is simple 1 colour cut vinyl logos
