Home Forums Sign Making Discussions Vinyl which way is the best to roll up banners after doing them?
  • which way is the best to roll up banners after doing them?
    Posted by carbon on 8 May 2004 at 19:26
    Ok this might be a daft question but here goes,
    once the vinyl has been applied to the banner which way is the best to roll it up, vinyl inside, outside or doesn’t it make any difference
    advice greatly appreciated
    thanks
    Robert Lambie replied 21 years, 6 months ago 5 Members · 7 Replies
  • 7 Replies
    8 May 2004 at 19:31
    hi chris!!
    the best way would be rolled vinyl on the outside!! i used to do the opposite!! 😮 until i read a thread on here somewhere, advising the other way!! 😛 it stops the vinyl crinkling!! 😀
    Nik
  • carbon
    8 May 2004 at 21:00
    Thanks Nik
    I wasn’t 100% sure so thanks for the quick reply
  • Nobby Thomas
    29 May 2004 at 20:02
    Outside for sure, I do a lot of mail order so have learnt the hard way!! 😥 😥
  • slobo
    2 June 2004 at 08:08
    of course always graphic and letterin face out
  • slobo
    2 June 2004 at 08:11
    onother things never fold banners. Better use cardborad roll of vinyl roll
    and roll banner on that.
  • carbon
    2 June 2004 at 17:08
    thanks for the replies to this, outside it is then 😀
    2 June 2004 at 17:58
    yeh, i agree.. roll with text on the outside is best.
    like slobo said.. a card tube is handy if you are posting it or if the banner is wide. stops the banner folding and causing bad kinks.
    also.. if your not using any sort of core to keep it stiff.. do not use an elastic band to hold it. or should i say, dont use a tight/strong band,, because again, it can cause creases,kinks in the banner when the customer unrolls it. couple of bits of masking tape holds fine. 😉
