Which substrate should i use for fitting onto a wall?
I have a customer who wants two signs supplying and fitting to the wall outside his office. He wants a 1000mm x 400mm sign above the door with the company name and logo and then a 400 x 600 sign by the door with a list of what they can offer. I have proposed using aluminium composite board that will be fitted in a frame but he has decided that frames look untidy and he would like the signs to be fitted with stand off locator’s.
Would I still be able to use 3mm ali composite for this and just drill the holes for the locators slightly loose or is the expansion/contraction going to be too much? Failing that what other substrate should I look at using?
