Home Forums Vinyl Cutter Discussions PCUT Vinyl Cutters Which blades are the correct ones to use on pcut 630 please?
  • Which blades are the correct ones to use on pcut 630 please?
    Posted by colin rawson on 31 May 2007 at 16:55
    hope ive got this in the right forum
    ive been looking to get some spare blades for my pcut 630
    i will be cutting letters and logos as small as 10mm upto about 90mm
    the company selling the blades do 2 types 30 & 45 degrees
    which is the best for me
    thanks
    in advance
    colin
    colin rawson replied 18 years, 6 months ago 3 Members · 5 Replies
    31 May 2007 at 17:08
    depends what type of vinyl you are using, the different blade angles are for cutting different types of material.
  • colin rawson
    31 May 2007 at 17:22
    it says on the back of the vinyl
    ri-mark series l&m
    if that meens anything
    thanks
    colin
  • Gav
    31 May 2007 at 18:17
    45 degree blades are the ones you want. You can buy them online from signwizard.
    31 May 2007 at 18:27
    Sounds like you just need them for ordinary vinyl in which case the 45 deg blades would be the ones to buy. Not really sure what 30 deg blades would be used for, for thicker material like sandblast and I believe garment films then most plotters use a 60 deg blade.
  • colin rawson
    31 May 2007 at 19:00
    thanks for the replies will order 45 degree 1s
    thanks to all
    colin
