Home Forums Sign Making Discussions General Sign Topics Which application tape do people use apart from oracal?
  • Which application tape do people use apart from oracal?
    Posted by Ade Brown on 10 September 2008 at 11:40
    Hi all,
    been using Oracle app tape for over 12 months now!!
    a few have mentioned the conform 4075!!
    any views on one or the other??
    Ade
    Ade Brown replied 17 years, 3 months ago 12 Members · 15 Replies
  • 15 Replies
  • Gary Birch
    10 September 2008 at 11:46
    I changed from the Oracol tape to conform and much prefer it. Apart from the extra cost that is. But it does lay much flatter and stays there too.
    Gary
  • Steve Underhill
    10 September 2008 at 13:31
    I bought 2 logs of perfectear from grafityp a while back, tears a little too easy when masking tape is pulled off it and seems to crease easy, but its ok once you get used to it, I also use oracal clear.
  • Ade Brown
    12 September 2008 at 07:49
    Hi Gary,
    have you tried it layed up for a period of time?
    Ade
  • Gary Birch
    12 September 2008 at 08:01
    Ade
    I have some here that has been rolled up since the end of June. Still absolutely fine. I do apply it with the eazytaper though which I think helps too.
    For the price difference I`d get a roll in and try it.
    Gary
  • Dave Harrison
    12 September 2008 at 10:14
    I have just switched from perfect tear to Oracal tape. . I really like the fact the oracal stuff is quite stretchy when laying down over vinyl. .. seems to go down really flat. I remember last year having some stuff from victory as it was on offer, it was horrendous ! It Wouldn’t lift the cut vinyl from the backing paper, I ended up putting two logs in the bin.
    12 September 2008 at 10:51
    Dave, should have put them in my bin, I use Victory’s Unitac paper application tape all the time and have no problems with it at all.
    Alan D
  • Warren Beard
    12 September 2008 at 11:12
    I also used Victory’s Unitac and also had problems with it, it was horrible. I now only use Oracal tape and find it really nice but only can compare to Unitac as haven’t used any others. I heard Conform was very nice and might try it in the near future just for a comparison.
    Warren
  • Jamie Wood
    12 September 2008 at 12:11
    We usually use Conform, and have no problems with it. Tried an Avery one
    today, and that was OK too.
    12 September 2008 at 12:20
    I have used Conform by R Tape since day one.
  • Tim Painter
    12 September 2008 at 12:26
    Conform R 4075 here……….as per Jill since day 1.
    On info from the kind soles on here 😀
  • Adrian Yeo
    12 September 2008 at 13:17
    R4075 used here too. Never really tried anything else because I’ve not had the need!
  • Jon Marshall
    12 September 2008 at 14:06
    You’re all kidding right? I find conform horrendous. Too flimsy, glue isn’t pressure sensitive, creates static, loads of creases if trying to cover large areas of solid vinyl etc.
    12 September 2008 at 17:08
    If Conform is the layflat stuff I found the same as Jon. It must be me as I have no problem with Unitac at all.
    Alan D
  • Peter Mindham
    12 September 2008 at 20:14
    I have been using the Oracal for ages and have just got in some of the clear. Will be trying it this weekend
  • Ade Brown
    12 September 2008 at 20:27
    I currently use both Oracle paper and clear – I am happy with it, although graphics that have been layed up and left for a week tend to lift on edges from backing paper.
    I also use the metamark clear now and again!!
    I have a 100mm role of conform 4075 to try!!
