Home Forums Vinyl Cutter Discussions General Cutter topics Where to buy plain liner paper rolls?
  • Where to buy plain liner paper rolls?
    Posted by Hugh Potter on 30 June 2016 at 15:56
    On my old 720 laminator I always used the old liner paper as a permanently fed base when laminating, the idea being that the laminator can be left alone once set up and no worries of the laminate sticking to the bottom roller. Now I have the 1400 laminator I don’t have any spare liner paper to run through it, I know that someone sells it as I’ve seen it, I thought it was Grafityp but they say they don’t..
    Any ideas please?
    thanks,
    Hugh
    Hugh Potter replied 9 years, 6 months ago 4 Members · 6 Replies
    30 June 2016 at 16:19
    What width do you need 1370 any good?
    I may have a roll kicking around from the take up on our laminator.
    30 June 2016 at 17:20
    1370 would be perfect David, thank you! I’ll drop you an email..
    Hugh
    30 June 2016 at 17:22
    Maybe stating the obvious, sorry. After you laminate first roll you will have the spent roll of carrying paper from then on?
    30 June 2016 at 18:30
    that’s got I got the last lot Rob, with this new one I’m swapping laminates about so have yet to run a decent length of it! once it’s set right I like to leave it loaded until such time as I need to change material or a new roll!
  • Kevin Flowers
    30 June 2016 at 18:42
    In over 15 years i never once used backing paper when laminating never had any problems with glue sticking to the rollers, I used a Makrolam 2r 1650, top hot roll
    30 June 2016 at 18:58
    quote Kevin Flowers:
    it’s something I started doing after having a few prints wrap themselves around the bottom roller, not an experience I want to repeat on a 1400 wide! it did it earlier but luckily only on a 600mm long print!
