Home › Forums › Sign Making Discussions › Vinyl › where can I source different thickness grades of Vinyl?
Posted by Aaron Powell on 6 June 2009 at 10:08Does anybody know where i can get different grades thickness of vinyl from i’m after something thick non tacky and i can cut (something like card but in vinyl)
Aaron Powell replied 16 years, 5 months ago 9 Members · 17 Replies -
not heard of any vinyl that thick mate, think the thickest Ive heard of is sand blast vinyl or a cheap paint mask vinyl. trouble with them is they only come in a few colours and i think thats depending on which supplier you buy from. i.e. white, black, or one we used to buy was like mucky rain water. :lol1:
I have been asked to cut some stencils out for a airbrush tattoo company i have look at other airbrush companys but one said that 10mm thick (now i know thats to thick)
Ah now I see,
spandex do a clear plastic, I thinks its acetate that is used in the edge for switch panels etc.
The polotter does not actualy cut through but scores it so it snaps easy.ask for a sample it may do what you want
We have a roll of the plastic from spandex, very expensive, you can use a leatherette product for this type of work I think.
quote Aaron Powell:I have been asked to cut some stencils out for a airbrush tattoo company i have look at other airbrush companys but one said that 10mm thick (now i know thats to thick)
i bet that was a usa site and i would think they mean 10 thou .25 mm very confusing when you read some of there specs
quote Tim Painter:Aaron what is the product called?
Tim.
Not a Clue
quote Jason Davies:We have a roll of the plastic from spandex, very expensive, you can use a leatherette product for this type of work I think.
Its not a supple as leather it need to be stiffer.. between plastic and vinyl..
Aaron
i think what you want is mylar, i have laser cut it to make tattooo stencils for someone who airbrushed them (temporary tattoos) etc. However i cut it by Laser but i believe you can cut it with a cutter as well. got mine from Handover & SonsKev
quote Kevin Flowers:Aaron
Great is it the same as the pictures above?
Aaron, try giving Edward Mathias a ring. The guy knows pretty much all there is to know about cutting different materials on a plotter.
looks a bit like the "thinner of the two" sign magnetic panel on a roll you can buy.
you could call anchor magnets or bisbell magnets… think its about £5 a metre x 24inch wide.as kev says, i would have thought laser cut would be best. i have cut stencils from my magnetic roll using our cnc router but no use for small intricate stuff like that as the movement motion of the router shifts the panel from the vacuum bed.
Thankyou for all your advise i knew it was good to join uksb 😀
I will give them a ring too Martin Thanks
Cheers Rob …
there are thicker vinyls out there.
http://www.ctn-uk.com/
these guys do a really thick vinyl called stratedar
this vinyl is used for wall coverings and the edge can even be sanded downalso try b brown in hemel, thay have vinyl wall coverings
Great got some coming Thanks
