Home › Forums › Vinyl Cutter Discussions › Mimaki Cutters › where can i source a serial cable for mutoh please?
Posted by Andrew Boyle on 13 September 2007 at 11:43Could anyone tell me the best place to buy a serial cable for a Mutoh SC1300.
Many Thanks – appreciate it
Andrew
Russell Huffer replied 18 years, 4 months ago 6 Members · 9 Replies -
Unless it’s wired up weird – your local independent PC shop should have one / make one up for you.
dave
If you are getting one made, your user manual might have the "pin outs" named, will make it easier to match up the ends.
Thanks for your help……..
Flynn Signs [and Victory] do them for the SC1300
serial cable arrived today……..
however although all the settings appear to be exactly the same I can’t seem to get the machine to poll size….although it recognises it’s there
any ideas….again many thanks
"cutter is not responding to poll size" I know it worked fine with LPT however it won’t cut on Com 1 with new serial cable
Not long had to do a new cable for my Mutoh, from memory 5 -5, 7-7, 2 -3 and 3 -2.
Are the only connections needed the problem i had was that the cable i bought was stright wired on pins 2 and 3 and needs to be crossover.
Russell
Hi All
What does this mean? I can’t seem to get the machine to poll size….
Thanks for any replies
graham -
In Flexi, when I go to cut I can click Poll Size and it gets the width of the vinyl currently loaded in the cutter, as measured by the cuttter when material was loaded.
This is only availible I belive on Mutoh when using serial but not parralel, lead, pinout important as this is bi directional data.
Russell.
